Teechart on canvas
We have a custom control and would like to draw a teechart on some part of the control. Is there a way to give tchart a canvas for it to draw on?
Thank you in advance for your help,
Tamara.
Hello Tamara,
I suggest you do something as next code where I have used a panel and I have drawn the chart into this panel:
            InitializeChart();
        Steema.TeeChart.TChart tChart2;
            tChart2 = new TChart();
            this.Paint +=new PaintEventHandler(Form1_Paint);
        void Form1_Paint(object sender, PaintEventArgs e)
            Graphics g = panel1.CreateGraphics();
            Rectangle rect = new Rectangle(panel1.Location.X, panel1.Location.Y, 400, 300);
            tChart2.Chart.Draw(g, rect);
Can you tell us if previous code works as you want? If it doesn’t help you, can you please explain exactly what you want achieve?
I hope will helps.
Hi Sandra,
Thank for providing the example. It works great for me.
However, when we use the contour series with my data, we ran into some problem that the series doesn’t appear on the chart.
Your contour_foot example data is continuous through out the x, y coordinate
Our data is not, some of our coordinate doesn’t have any data
I wonder is it a requirement that we should have continuous data through out the coordinate? Please advice.
Thanks so much for your time,
Tamara.
P.S. Following is the data we feed into contour series:
DieInfo[22.1052780151367, 172.5]= 1.25
DieInfo[22, 172]= 1.25
DieInfo[22, 157]= 1.25
DieInfo[22, 142]= 1.31578947368421
DieInfo[22, 127]= 1.28205128205128
DieInfo[36, 202]= 1.19047619047619
DieInfo[36, 187]= 1.21951219512195
DieInfo[36, 172]= 1.23456790123457
DieInfo[36, 157]= 1.20481927710843
DieInfo[36, 142]= 1.19047619047619
DieInfo[36, 127]= 1.21951219512195
DieInfo[36, 112]= 1.19047619047619
DieInfo[36, 97]= 1.21951219512195
DieInfo[50, 232]= 1.26582278481013
DieInfo[50, 217]= 1.20481927710843
DieInfo[50, 202]= 1.20481927710843
DieInfo[50, 187]= 1.21951219512195
DieInfo[50, 172]= 1.25
DieInfo[50, 157]= 1.20481927710843
DieInfo[50, 142]= 1.20481927710843
DieInfo[50, 127]= 1.19047619047619
DieInfo[50, 112]= 1.19047619047619
DieInfo[50, 97]= 1.21951219512195
DieInfo[50, 82]= 1.19047619047619
DieInfo[50, 67]= 1.20481927710843
DieInfo[64, 247]= 1.23456790123457
DieInfo[64, 232]= 0
DieInfo[64, 217]= 1.19047619047619
DieInfo[64, 202]= 1.25
DieInfo[64, 187]= 1.20481927710843
DieInfo[64, 172]= 1.21951219512195
DieInfo[64, 157]= 1.21951219512195
DieInfo[64, 142]= 1.21951219512195
DieInfo[64, 127]= 1.20481927710843
DieInfo[64, 112]= 1.19047619047619
DieInfo[64, 97]= 1.20481927710843
DieInfo[64, 82]= 1.20481927710843
DieInfo[64, 67]= 1.20481927710843
DieInfo[78, 262]= 1.21951219512195
DieInfo[78, 247]= 1.20481927710843
DieInfo[78, 232]= 1.20481927710843
DieInfo[78, 217]= 1.21951219512195
DieInfo[78, 202]= 1.20481927710843
DieInfo[78, 187]= 1.23456790123457
DieInfo[78, 172]= 1.21951219512195
DieInfo[78, 157]= 1.20481927710843
DieInfo[78, 142]= 1.21951219512195
DieInfo[78, 127]= 1.25
DieInfo[78, 112]= 1.20481927710843
DieInfo[78, 97]= 1.20481927710843
DieInfo[78, 82]= 1.19047619047619
DieInfo[78, 67]= 1.23456790123457
DieInfo[78, 52]= 1.20481927710843
DieInfo[78, 37]= 1.21951219512195
DieInfo[93, 262]= 1.25
DieInfo[93, 247]= 1.25
DieInfo[93, 232]= 1.25
DieInfo[93, 217]= 1.23456790123457
DieInfo[93, 202]= 1.21951219512195
DieInfo[93, 187]= 1.23456790123457
DieInfo[93, 172]= 1.21951219512195
DieInfo[93, 157]= 1.21951219512195
DieInfo[93, 142]= 1.23456790123457
DieInfo[93, 127]= 1.20481927710843
DieInfo[93, 112]= 1.20481927710843
DieInfo[93, 97]= 1.20481927710843
DieInfo[93, 82]= 1.20481927710843
DieInfo[93, 67]= 1.21951219512195
DieInfo[93, 52]= 1.19047619047619
DieInfo[93, 37]= 1.19047619047619
DieInfo[107, 277]= 1.21951219512195
DieInfo[107, 262]= 1.20481927710843
DieInfo[107, 247]= 1.21951219512195
DieInfo[107, 232]= 1.26582278481013
DieInfo[107, 217]= 1.21951219512195
DieInfo[107, 202]= 2.7027027027027
DieInfo[107, 187]= 1.25
DieInfo[107, 172]= 1.23456790123457
DieInfo[107, 157]= 1.23456790123457
DieInfo[107, 142]= 1.21951219512195
DieInfo[107, 127]= 1.25
DieInfo[107, 112]= 1.21951219512195
DieInfo[107, 97]= 1.20481927710843
DieInfo[107, 82]= 1.21951219512195
DieInfo[107, 67]= 1.21951219512195
DieInfo[107, 52]= 1.21951219512195
DieInfo[107, 37]= 1.20481927710843
DieInfo[107, 22]= 1.20481927710843
DieInfo[121, 277]= 1.25
DieInfo[121, 262]= 1.25
DieInfo[121, 247]= 1.23456790123457
DieInfo[121, 232]= 1.23456790123457
DieInfo[121, 217]= 1.23456790123457
DieInfo[121, 202]= 1.21951219512195
DieInfo[121, 187]= 1.23456790123457
DieInfo[121, 172]= 1.23456790123457
DieInfo[121, 157]= 1.21951219512195
DieInfo[121, 142]= 1.21951219512195
DieInfo[121, 127]= 1.20481927710843
DieInfo[121, 112]= 1.20481927710843
DieInfo[121, 97]= 1.20481927710843
DieInfo[121, 82]= 1.20481927710843
DieInfo[121, 67]= 1.20481927710843
DieInfo[121, 52]= 1.21951219512195
DieInfo[121, 37]= 1.21951219512195
DieInfo[121, 22]= 1.20481927710843
DieInfo[135, 277]= 1.20481927710843
DieInfo[135, 262]= 1.21951219512195
DieInfo[135, 247]= 1.2987012987013
DieInfo[135, 232]= 1.25
DieInfo[135, 217]= 1.21951219512195
DieInfo[135, 202]= 1.21951219512195
DieInfo[135, 187]= 1.21951219512195
DieInfo[135, 172]= 1.23456790123457
DieInfo[135, 157]= 1.23456790123457
DieInfo[135, 142]= 1.21951219512195
DieInfo[135, 127]= 1.21951219512195
DieInfo[135, 112]= 1.23456790123457
DieInfo[135, 97]= 1.20481927710843
DieInfo[135, 82]= 1.25
DieInfo[135, 67]= 1.26582278481013
DieInfo[135, 52]= 1.25
DieInfo[135, 37]= 1.23456790123457
DieInfo[135, 22]= 1.20481927710843
DieInfo[150, 277]= 1.21951219512195
DieInfo[150, 262]= 1.23456790123457
DieInfo[150, 247]= 1.23456790123457
DieInfo[150, 232]= 1.21951219512195
DieInfo[150, 217]= 1.21951219512195
DieInfo[150, 202]= 1.21951219512195
DieInfo[150, 187]= 1.21951219512195
DieInfo[150, 172]= 1.21951219512195
DieInfo[150, 157]= 1.20481927710843
DieInfo[150, 142]= 1.21951219512195
DieInfo[150, 127]= 1.23456790123457
DieInfo[150, 112]= 1.20481927710843
DieInfo[150, 97]= 1.20481927710843
DieInfo[150, 82]= 1.23456790123457
DieInfo[150, 67]= 1.25
DieInfo[150, 52]= 1.21951219512195
DieInfo[150, 37]= 1.20481927710843
DieInfo[150, 22]= 1.20481927710843
DieInfo[164, 277]= 1.2987012987013
DieInfo[164, 262]= 1.23456790123457
DieInfo[164, 247]= 1.21951219512195
DieInfo[164, 232]= 1.21951219512195
DieInfo[164, 217]= 1.23456790123457
DieInfo[164, 202]= 2.63157894736842
DieInfo[164, 187]= 1.21951219512195
DieInfo[164, 172]= 1.21951219512195
DieInfo[164, 157]= 1.23456790123457
DieInfo[164, 142]= 1.20481927710843
DieInfo[164, 127]= 1.21951219512195
DieInfo[164, 112]= 1.21951219512195
DieInfo[164, 97]= 1.21951219512195
DieInfo[164, 82]= 1.21951219512195
DieInfo[164, 67]= 1.20481927710843
DieInfo[164, 52]= 1.21951219512195
DieInfo[164, 37]= 1.21951219512195
DieInfo[164, 22]= 1.20481927710843
DieInfo[178, 277]= 1.26582278481013
DieInfo[178, 262]= 1.25
DieInfo[178, 247]= 1.21951219512195
DieInfo[178, 232]= 1.21951219512195
DieInfo[178, 217]= 1.21951219512195
DieInfo[178, 202]= 1.23456790123457
DieInfo[178, 187]= 1.23456790123457
DieInfo[178, 172]= 1.23456790123457
DieInfo[178, 157]= 1.20481927710843
DieInfo[178, 142]= 1.20481927710843
DieInfo[178, 127]= 1.23456790123457
DieInfo[178, 112]= 1.20481927710843
DieInfo[178, 97]= 1.20481927710843
DieInfo[178, 82]= 1.21951219512195
DieInfo[178, 67]= 1.21951219512195
DieInfo[178, 52]= 1.21951219512195
DieInfo[178, 37]= 1.20481927710843
DieInfo[178, 22]= 1.21951219512195
DieInfo[192, 277]= 1.26582278481013
DieInfo[192, 262]= 1.26582278481013
DieInfo[192, 247]= 1.21951219512195
DieInfo[192, 232]= 1.28205128205128
DieInfo[192, 217]= 1.21951219512195
DieInfo[192, 202]= 1.26582278481013
DieInfo[192, 187]= 1.21951219512195
DieInfo[192, 172]= 1.23456790123457
DieInfo[192, 157]= 1.21951219512195
DieInfo[192, 142]= 1.23456790123457
DieInfo[192, 127]= 1.21951219512195
DieInfo[192, 112]= 1.23456790123457
DieInfo[192, 97]= 1.21951219512195
DieInfo[192, 82]= 1.25
DieInfo[192, 67]= 1.25
DieInfo[192, 52]= 1.23456790123457
DieInfo[192, 37]= 1.23456790123457
DieInfo[192, 22]= 0
DieInfo[206, 262]= 1.20481927710843
DieInfo[206, 247]= 1.21951219512195
DieInfo[206, 232]= 1.23456790123457
DieInfo[206, 217]= 1.23456790123457
DieInfo[206, 202]= 1.21951219512195
DieInfo[206, 187]= 1.21951219512195
DieInfo[206, 172]= 1.21951219512195
DieInfo[206, 157]= 1.25
DieInfo[206, 142]= 0
DieInfo[206, 127]= 1.20481927710843
DieInfo[206, 112]= 1.21951219512195
DieInfo[206, 97]= 1.21951219512195
DieInfo[206, 82]= 1.23456790123457
DieInfo[206, 67]= 1.21951219512195
DieInfo[206, 52]= 1.23456790123457
DieInfo[206, 37]= 1.21951219512195
DieInfo[221, 262]= 1.23456790123457
DieInfo[221, 247]= 1.23456790123457
DieInfo[221, 232]= 1.23456790123457
DieInfo[221, 217]= 1.21951219512195
DieInfo[221, 202]= 1.23456790123457
DieInfo[221, 187]= 1.21951219512195
DieInfo[221, 172]= 1.21951219512195
DieInfo[221, 157]= 1.21951219512195
DieInfo[221, 142]= 1.23456790123457
DieInfo[221, 127]= 1.23456790123457
DieInfo[221, 112]= 1.23456790123457
DieInfo[221, 97]= 1.23456790123457
DieInfo[221, 82]= 1.23456790123457
DieInfo[221, 67]= 1.26582278481013
DieInfo[221, 52]= 1.31578947368421
DieInfo[221, 37]= 1.26582278481013
DieInfo[235, 247]= 1.26582278481013
DieInfo[235, 232]= 1.25
DieInfo[235, 217]= 1.23456790123457
DieInfo[235, 202]= 1.23456790123457
DieInfo[235, 187]= 1.23456790123457
DieInfo[235, 172]= 1.25
DieInfo[235, 157]= 1.21951219512195
DieInfo[235, 142]= 1.21951219512195
DieInfo[235, 127]= 1.21951219512195
DieInfo[235, 112]= 1.23456790123457
DieInfo[235, 97]= 1.21951219512195
DieInfo[235, 82]= 1.21951219512195
DieInfo[235, 67]= 1.23456790123457
DieInfo[235, 52]= 1.21951219512195
DieInfo[249, 232]= 0
DieInfo[249, 217]= 1.23456790123457
DieInfo[249, 202]= 0
DieInfo[249, 187]= 1.25
DieInfo[249, 172]= 1.26582278481013
DieInfo[249, 157]= 1.25
DieInfo[249, 142]= 1.25
DieInfo[249, 127]= 0
DieInfo[249, 112]= 1.25
DieInfo[249, 97]= 1.28205128205128
DieInfo[249, 82]= 1.28205128205128
DieInfo[249, 67]= 1.28205128205128
DieInfo[263, 202]= 0
DieInfo[263, 187]= 1.26582278481013
DieInfo[263, 172]= 1.23456790123457
DieInfo[263, 157]= 1.26582278481013
DieInfo[263, 142]= 1.23456790123457
DieInfo[263, 127]= 1.25
DieInfo[263, 112]= 1.23456790123457
DieInfo[263, 97]= 1.26582278481013
DieInfo[277, 172]= 1.2987012987013
DieInfo[277, 157]= 0
DieInfo[277, 142]= 0
DieInfo[277, 127]= 1.47058823529412
Hello Tamara,
I recommend you take a look in here to understand how you must add values in the 3D Grid Series.
