Error 1 The TeeChart version = 4.1.2011.4192, Culture = neutral, PublicKeyToken = 9c8126276c77bdb7 assembly is not registered for COM interop. Register them with regasm.exe tlb
what could be the reason? How to solve?
Hello AGF,
I recommend you that take a look in this link and follow all steps to try to solve your problem. If you do all of suggestions there are in the link and your error still appears, please let me know.
I hope will helps.
Dear Sandra,
sorry, but it dont helps … and sorry i have no time to play with the registry …
the problem occurs since the last automatic update of ms windows 7 on me dev machine and and the compiling of some projects crashs …
could you please provide an Installer for VS 2008 with the lastest build please?
Hello AFG,
Can you tell us, in which type of project, error appears? Moreover, can you please send a project so we can reproduce this problem here?
Dear Sandra,
it is an class library … an i can’t give you an example because http://www.teechart.net/support/viewtopic.php?f=4&t=12350 … reason’s …
i think the best way is, that you provide an new installer for vsto2008 with the latest version or do you have other ideas to get your package runnig ?
Thanks and Best Regards
Hello AGF,
I belive that a new installer doesn’t solve your problem, but you can check if this solve your problem, updating your version of TeeChart.Net to newest, that you find in Customer download page. On the other hand, I recommend that take a look in this link where explain how you do to register assembly for Com Interop. Please, check if with previous recommendation your problem is solved. Moreover, we would be grateful if you can try to made a simple project to recreate their environment so we can reproduce your exactly problem here.
