switching from XP to Vista to Win7 I have learnt that I can use
DesktopFont := true;
to adopt the appliction to the standard fonts of the operating system.
TeeChart defines a lot of fonts (according to the chart editor). It seems that these fonts do not adopt to the desktop font.
How to achieve the correct behaviour or how to set all fonts by the application program (do I really need to define the font of each TeeChart component) ?
switching from XP to Vista to Win7 I have learnt that I can use DesktopFont := true; to adopt the appliction to the standard fonts of the operating system.TeeChart defines a lot of fonts (according to the chart editor). It seems that these fonts do not adopt to the desktop font.
I have added your request in wish list with number [TV52015164]to be revised in future releases.
You can define font of each TeeChart components for example in design time with Editor, following next steps:
-Open TChart Editor
-Select Tabs Chart->General->Fonts.
-Select All Fonts with checkbox.
-Select to the Name font as you want, with comboBox.
setting the fonts by the ChartEditor is clear.
But I like to define/change it at runtime. Then I can e.g. automatically set the font to Screen.IconFont (which may vary from XP to Vista to Windows7) How to set the different control.font properties at runtime?
In that case you can do something similar to what the editor does (see example below). If you are a source code customer you can have a look at TeeEdiGene.pas.
unit Unit1;
interface
uses
Dialogs, TeEngine, Series, TeeComma, ExtCtrls, TeeProcs, Chart, StdCtrls,
TeCanvas;
type
TForm1 = class(TForm)
Chart1: TChart;
TeeCommander1: TTeeCommander;
Series1: TBarSeries;
private
{ Private declarations }
FontList : TStringList;
function SelectedFont(Index:Integer):TTeeFont;
public
{ Public declarations }
var
Form1: TForm1;
implementation
{$R *.dfm}
uses TeeEdiGene;
function TForm1.SelectedFont(Index:Integer):TTeeFont;
var tmp : TObject;
tmp:=FontList.Objects[Index];
if tmp is TTeeCustomShape then
result:=TTeeCustomShape(tmp).Font
if tmp is TChartAxis then
result:=TChartAxis(tmp).LabelsFont
{$IFDEF D6}
if tmp is TChartSeries then
result:=FontOfPersistent(tmp as TPersistent,TChartSeries(tmp).Marks.Font)
result:=FontOfPersistent(tmp as TPersistent);
{$ELSE}
result:=nil;
{$ENDIF}
var t : Integer;
tmp : TTeeFont;
FontList:=TStringList.Create;
FontList.Clear;
TFormTeeGeneral.GetChartObjects(Chart1, FontList, True);
for t:=0 to FontList.Count-1 do
tmp:=SelectedFont(t);
tmp.Name:='Times New Roman';
tmp.Size:=14;
tmp.Style:=[fsBold];
tmp.Color:=clRed;
tmp.InterCharSize:=5;
tmp.Shadow.HorizSize:=5;
tmp.Shadow.VertSize:=12;
tmp.Shadow.Color:=clRed;
tmp.Shadow.Visible:=True;
tmp.Shadow.Transparency:=50;
tmp.Shadow.Smooth:=True;
tmp.Gradient.Visible:=True;
end.
