Format ValueMarkText
I am using:
AnnotationChart4.Text = "Point: " & AIndex.ToString() + Value: " & Ternary1.ValueMarkText(AIndex)
How do I format the ValueMarkText?
I have tried TChart1.Series(0).ValueFormat = “##0
I have also tried:
TChart1.Series(0).ValueFormat = String.Format(“##0”)
and
AnnotationChart4.Text = String.Format(“Point: {0} Value: {1:##0}”, AIndex.ToString(), Ternary1.ValueMarkText(AIndex))
Hello lilo,
I have reproduce your problem and I have added it as Feature request with number [TF02015258] to be considered for inclusion in futures versions of TeeChart.Net.
Hi lilo,
You can also split mark text string and format it as in this example:
            InitializeChart();
        private Steema.TeeChart.Tools.Annotation annotation1;
        private Steema.TeeChart.Styles.Ternary ternary1;
            ternary1 = new Steema.TeeChart.Styles.Ternary(tChart1.Chart);
            ternary1.FillSampleValues();
            annotation1 = new Steema.TeeChart.Tools.Annotation(tChart1.Chart);
            tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
        void tChart1_MouseMove(object sender, MouseEventArgs e)
            int index = ternary1.Clicked(e.X, e.Y);
            if (index != -1)
                string tmp = ternary1.ValueMarkText(index);
                string[] tmpArray = tmp.Split(' ');
                tmp = " ";
                for (int i = 0; i < tmpArray.Length; i++)
                    tmp += String.Format("{0:##0}", tmpArray[i]) + " ";
                annotation1.Text = String.Format("Point: {0} Value: {1}", index.ToString(), tmp);
            double m = 5;
            this.Text = String.Format("{0:##0}", m.ToString());
If this doesn’t help please let us know what do you want to get exactly.
This is the solution to my problem.
This code worked:
Dim tmp As String, tmp1 As String, tmp2 As String, tmp3 As String, tmparray() As String
tmp = Ternary1.ValueMarkText(AIndex)
tmparray = tmp.Split(" ")
tmp = " "
tmp1 = Format(Val(tmparray(0)), “##0”)
tmp2 = Format(Val(tmparray(1)), “##0”)
tmp3 = Format(Val(tmparray(2)), “##0”)
AnnotationChart4.Text = String.Format(“Point: {0} {4}Value: {1} {2} {3}”, AIndex.ToString(), tmp1, tmp2, tmp3, vbCrLf)
