Align Left and Custom Axis titles when at angle 90
When Left axis and Left Custom Axis titles are at a 90 degree angle, how is it possible to align them so that they line up. (D2010, TeeChart 8.06). It appears that their offset from the panel is determined by each Axis’ max label width. Is there a way to get all of the axes to calculate offset based on ALL of the labels involved?
Hi DanKerlee,
I’m afraid that the title position is calculated internally and, as you’ve seen, relative to its own MaxLabelsWidth. What you could do is to hide the titles and draw them using custom drawing techniques:
uses series, TeCanvas;
var i, j: Integer;
  Chart1.View3D:=false;
  for i:=0 to 1 do with Chart1.AddSeries(TFastLineSeries.Create(self)) do
    Chart1[i].Add(Random*100+i*10000);
    for j:=0 to 24 do Chart1[i].Add(Chart1[i].YValue[Chart1[i].Count-1] + Random*10 - 5);
  Chart1.CustomAxes.Add;
  Chart1[1].CustomVertAxis:=Chart1.CustomAxes[0];
  Chart1.Axes.Left.EndPosition:=50;
  Chart1.CustomAxes[0].StartPosition:=50;
  Chart1.Axes.Left.Title.Caption:='Left Axis';
  Chart1.CustomAxes[0].Title.Caption:='Custom Axis';
{  Chart1.Axes.Left.Title.Angle:=90;
  Chart1.CustomAxes[0].Title.Angle:=90;}
  Chart1.Axes.Left.Title.Visible:=false;
  Chart1.CustomAxes[0].Title.Visible:=false;
  Chart1.MarginLeft:=5;
var i: Integer;
    tmp1, tmp2: Double;
  for i:=0 to Chart1.Axes.Count-1 do
    with Chart1.Axes[i] do
    if not Horizontal then
      tmp1:=(CalcPosValue(Minimum+(Maximum-Minimum)/2));
      tmp2:=Form1.Canvas.TextWidth(Title.Caption)/2;
      Chart1.Canvas.RotateLabel(10,Round(tmp1+tmp2),Title.Caption,90);
