Problem adding 9th Assembly
TeeGofer general
Locked
matt
Post by matt » Wed Aug 02, 2006 9:01 pm
I have a large product that we are trying to generate help documentation
for. We have many assemblies that need to be in the Teegofer project. When
I attempt to add the 9th assembly to the project I get an Message Box error
stating:
Insertion index was out of range. Must be non-negative and less than or
equal to size.
Parameter name: index
Is this a hard limitation of the product or is there a
worked around or fix/patch available.
I am running V2.6.2200.29115
The Solutions are built in Visual Studio.net 2005 and the C# language.
Post by Marc » Mon Aug 21, 2006 9:57 am
Are you able to send us the project for us to be able to debug the issue? You could strip out real functionality if you wish as we'll only need to class structure itself to detect problems.
If possible you could leave it at news://www.steema.net/steema.public.attachments newsgroup.
With thanks.
Locked
