Please extract, open and run the attached sample project.
Click the Optins Button
Go to Chart -> Axes->SubAxes
Click on Visible
When you turn the Visible property on, you will get:
06/21/2023 08:39:04.13 System.NullReferenceException: Object reference not set to an instance of an object.
at Steema.TeeChart.Editors.AxisEditor.cbVisible_CheckedChanged(Object sender, EventArgs e)
Kind Regards,
Kris Culin
Bentley Systems, Inc.
Checking On SubAxes Visible Property Causes Exception
- TeeChartNET60.zip
- Sample Project
- (8.32 KiB) Downloaded 656 times
- Guru
Re: Checking On SubAxes Visible Property Causes Exception
thank you for reporting this issue to us. We have added it to our issue tracking software with id=2620, and we attach the git diff as 'diff.md' within 'diff.zip' so you can keep your sources up to date.
Hi Christopher,
Thank you for the fix and the diff so I can keep the source up-to-date.
Kind Regards,
Kris Culin
Kind Regards,
Kris Culin
