xsLiu
Post
by xsLiu » Wed Sep 30, 2020 2:01 am
I hope to show Titles using the same Color with its corresponding Series in a ChartListBox, but Title‘s Color is not consistent with SeriesColor in ChartListBox.
with aChartListBox do
Chart := aChart;
EnableChangeType := false;
EnableChangeColor := true;
EnableDragSeries := false;
ShowSeriesIcon := false;
ShowActiveCheck := true;
ShowSeriesColor := true;
ShowSeriesTitle := true;
FontSeriesColor := true;
AllowDeleteSeries := false;
AllowAddSeries := false;
- Color.jpg (5.35 KiB) Viewed 14046 times
- Site Admin
Post
by Yeray » Wed Sep 30, 2020 9:16 am
It seems to work fine for me here:
- Project1_2020-09-30_11-15-02.png (14.41 KiB) Viewed 14038 times
var Chart1: TChart;
ChartListBox1: TChartListBox;
Chart1:=TChart.Create(Self);
ChartListBox1:=TChartListBox.Create(Self);
with Chart1 do
Parent:=Self;
View3D:=False;
AddSeries(TBarSeries).FillSampleValues;
with TLineSeries(AddSeries(TLineSeries)) do
FillSampleValues;
Pen.Width:=2;
with ChartListBox1 do
Parent:=Self;
Left:=Chart1.Width;
Chart := Chart1;
xsLiu
Post
by xsLiu » Thu Oct 01, 2020 3:00 am
Please find attached.
- Point3D.jpg (66.09 KiB) Viewed 14030 times
- Point3D.zip
- (54.15 KiB) Downloaded 778 times
- Site Admin
Post
by Yeray » Thu Oct 01, 2020 6:30 am
You are setting the series LinePen.Color
, which is ok for the lines connecting the 3d points, but you should set the main series' Color
xsLiu
Post
by xsLiu » Mon Sep 27, 2021 4:41 am
How to change the Color tag/band (between ActiveCheck and SeriesTitle) from “square” to “line”?
xsLiu
Post
by xsLiu » Mon Sep 27, 2021 9:02 am
Please find the attached file and the hand tag.
- pp.png (15.67 KiB) Viewed 9186 times
- Site Admin
Post
by Yeray » Mon Sep 27, 2021 9:36 am
Depending on the series style it will be changing the Series'
Pointer.Color
, or just the Series'
Color
. Ie
TBarSeries(Chart1[0]).Color:=clRed;
TPoint3DSeries(Chart1[0]).Pointer.Color:=clRed;
xsLiu
Post
by xsLiu » Mon Sep 27, 2021 2:00 pm
I want to change its shape shown in the ChartListBox, not color.
- Site Admin
Post
by Yeray » Mon Sep 27, 2021 5:05 pm
Ups.
In that case you could use a dummy
TLineSeries
- which symbol is drawn as a "line" when in 2D - and hide the
TBarSeries
- which is drawn as a "square" when in 2D - from the legend and editor. Ie:
uses Series;
Chart1.View3D:=False;
Chart1.Color:=clWhite;
Chart1.Walls.Back.Visible:=False;
with Chart1.AddSeries(TBarSeries) do
FillSampleValues;
ShowInLegend:=False;
ShowInEditor:=False;
Title:='Series1';
//dummy series for the legend
with Chart1.AddSeries(TLineSeries) do
Title:=Chart1[0].Title;
Color:=Chart1[0].Color;
FillSampleValues;
Title:='Series2';
ChartListBox1.Chart:=Chart1;
- chartlist_dummy_symbol.png (13.07 KiB) Viewed 9171 times
