Labels for horizontal series
EdDressel
Post by EdDressel » Fri Mar 06, 2020 12:26 am
Attached is a simple demo where the horizontal series caption has two lines. Works fine.
My customer wants two modifications that I do not know how to do:
1) They would like the left axis labels to be right-aligned.
2) They would the second line (the value) bolded.
Are either of those possible?
Thank you,
Ed Dressel
Horz Series Left Axis Caption.zip
(1.97 KiB) Downloaded 764 times
Ed Dressel
President
RetireReady Solutions
Re: Labels for horizontal series
Post by Yeray » Fri Mar 06, 2020 11:21 am
Is this what you are trying to achieve?
This is the code I used to draw the above:
constructor TForm1.Create(aOwner: TComponent);
var
  lValue: currency;
  I: Integer;
  lCaption: string;
  inherited;
  for I := 1 to 5 do begin
    lValue := Trunc(Random(1000));
    lCaption := Format('Item #%d'+sLineBreak+'<b>%.0m</b>', [I, lValue]);
    Series1.AddBar(lValue, lCaption, clTeeColor);
  Chart1.Axes.Left.LabelsFormat.TextAlignment:=taRightJustify;
  Chart1.Axes.Left.LabelsFormat.TextFormat:=ttfHtml;
As you can see I'm using Html format to customize part of the labels. Note there was a bug I've just fixed: #2294.
EdDressel
Post by EdDressel » Thu Mar 12, 2020 8:38 pm
That's cool... but I don't know how you did that--attached is my demo that neither right aligns the values not bolds the items.
What am I doing wrong?
Ed Dressel
Horz Series Left Axis Caption 2.zip
(6.73 KiB) Downloaded 779 times
Ed Dressel
President
Post by Yeray » Fri Mar 13, 2020 11:41 am
You missed this part in your code:
EdDressel
Post by EdDressel » Fri Mar 13, 2020 5:12 pm
Perfect. Thank you.
Ed Dressel
President
