AxisBehind and inverted axes
Toreba
Post by Toreba » Tue Feb 12, 2019 12:59 pm
Is there a setting somewhere that allows the axes to be drawn over the series lines, but the grid lines to remain under the series?
Toreba
Re: AxisBehind and inverted axes
Post by Yeray » Mon Feb 18, 2019 11:06 am
You could set the axes to be drawn on top setting DrawBehind to False. Then, you could Hide the Grids and manually draw them at OnBeforeDrawSeries event. Ie:
uses Series;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Chart1.Axes.Behind:=False;
  Chart1.Axes.Left.PositionPercent:=50;
  Chart1.Axes.Left.Grid.Hide;
  Chart1.Axes.Bottom.PositionPercent:=50;
  Chart1.Axes.Bottom.Grid.Hide;
  Chart1.AddSeries(TBarSeries).FillSampleValues(3);
  Chart1.Draw;
type TChartAxisAccess = class(TChartAxis);
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
  Chart1.Axes.Left.Grid.Show;
  TChartAxisAccess(Chart1.Axes.Left).DrawGrids(Chart1.Axes.Left.Items.Count);
  Chart1.Axes.Bottom.Grid.Show;
  TChartAxisAccess(Chart1.Axes.Bottom).DrawGrids(Chart1.Axes.Bottom.Items.Count);
