How can I draw nice 3D Arrows to depict axes (a,b,c)
axrDegen
Post by axrDegen » Mon Feb 11, 2019 8:05 pm
How can I draw nice 3D arrows like in the attached picture?
By using the code below I only get "flat" arrows
and can't draw an arrow in Z direction:
var
  tmpX,tmpY,tmpZ: Integer;
  FromPoint,ToPoint: TPoint;
  tmpY := Chart.ChartYCenter + Round(Chart.Canvas.RotationCenter.Y);
  tmpX := Chart.ChartXCenter + Round(Chart.Canvas.RotationCenter.X);
  tmpZ := (Chart.Width3D div 2) + Round(Chart.Canvas.RotationCenter.Z);
  StrainChart.Canvas.Pen.Color := clRed;
  StrainChart.Canvas.Pen.Width := 4;
  StrainChart.Canvas.Pen.Style := psSolid;
  FromPoint.X := Chart.ChartRect.Left;
  FromPoint.Y := tmpY;
  ToPoint.X := Chart.ChartRect.Right;
  ToPoint.Y := tmpY;
  Chart.Canvas.Arrow(True, FromPoint, ToPoint, 50, 50, tmpZ);
  FromPoint.X := tmpX;
  FromPoint.Y := Chart.ChartRect.Bottom;
  ToPoint.X := tmpX;
  ToPoint.Y := StrainChart.ChartRect.Top;
Re: How can I draw nice 3D Arrows to depict axes (a,b,c)
Post by Yeray » Mon Feb 18, 2019 9:11 am
You can give it a try at the Vector series. Ie:
uses TeeSurfa;
  with Chart1 do
    Chart3DPercent:=100;
    Aspect.Orthogonal:=False;
    Aspect.Zoom:=70;
    Legend.Hide;
    Axes.Left.SetMinMax(0,10);
    Axes.Bottom.SetMinMax(0,10);
    Axes.Depth.SetMinMax(0,10);
    Axes.Depth.Visible:=True;
    Axes.Left.Increment:=1;
    Axes.Bottom.Increment:=1;
    Axes.Depth.Increment:=1;
  with Chart1.AddSeries(TVector3DSeries) as TVector3DSeries do
    Color:=clRed;
    Pen.Width:=2;
    ArrowHeight:=10;
    ArrowWidth:=10;
    AddVector(5,5,5,0,5,5,'', clRed);
    AddVector(5,5,5,10,5,5,'', clRed);
    AddVector(5,5,5,5,0,5,'', clRed);
    AddVector(5,5,5,5,10,5,'', clRed);
    AddVector(5,5,5,5,5,0,'', clRed);
    AddVector(5,5,5,5,5,10,'', clRed);
axrDegen
Post by axrDegen » Mon Feb 18, 2019 11:36 am
Hello Yeray,
that's a nice solution, interesting is that I can't get the Labels to work in call "AddVector", like:
AddVector(5,5,5,0,5,5,'Vector A', clRed);
Do you have a solution for that?
Also it would be nice to have real 3D Arrows on top of the Vector lines.
Post by Yeray » Tue Feb 19, 2019 11:17 am
Try turning the Marks visible:
    Marks.Visible:=True;
    Marks.Style:=smsLabel;
How would you like them to look exactly?
axrDegen
Post by axrDegen » Tue Feb 19, 2019 12:39 pm
Ok, that makes them appear, but all the Labels are displayed together at the center point, please see the screenshot:
How Can I display the labels at the end of the Arrows?
The Arrowheads I would expect to be shown as a (3D) Cone, see below:
Post by Yeray » Wed Feb 20, 2019 11:18 am
I'm afraid this is not possible right now.
I've created a new ticket in the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2161
axrDegen
Post by axrDegen » Wed Feb 20, 2019 12:42 pm
Ok, that is about making it nice, but what about the markers/labels, how can I get these displayed correctly?
Post by Yeray » Thu Feb 21, 2019 3:55 pm
Sorry, I missed that point.
You could use marks custom positioning at OnGetMarkText event. Ie:
procedure TForm1.VectorGetMarkText(Sender:TChartSeries; ValueIndex:Integer; var MarkText:String);
  if Assigned(Sender) and (ValueIndex>-1) and (ValueIndex<Sender.count) and
     Assigned(Sender.Marks.Positions) and Assigned(Sender.Marks.Positions[ValueIndex]) then
    with TVector3DSeries(Sender), Marks.Positions[ValueIndex] do
      Custom:=True;
      LeftTop:=ParentChart.Canvas.Calculate3DPosition(CalcXPosValue(EndXValues[ValueIndex]),
                                                      CalcYPosValue(EndYValues[ValueIndex]),
                                                      ParentChart.Axes.Depth.CalcPosValue(EndZValues[ValueIndex]));
axrDegen
Post by axrDegen » Fri Feb 22, 2019 7:50 am
Thank you Yeray, that works for X and Y but not for Z, please see screenshot:
Note that I use the Min/Max of another series to calculate the Max values for the Vectors, like that:
    MaxX := Max(FPoint3DSeries.MaxXValue, Abs(FPoint3DSeries.MinXValue));
    MaxY := Max(FPoint3DSeries.MaxYValue, Abs(FPoint3DSeries.MinYValue));
    MaxZ := Max(FPoint3DSeries.MaxZValue, Abs(FPoint3DSeries.MinZValue));
    FAxesSeries.AddVector(0,0,0, MaxX,0,0, 'a', clRed);
    FAxesSeries.AddVector(0,0,0, 0,MaxY,0, 'b', clGreen);
    FAxesSeries.AddVector(0,0,0, 0,0,MaxZ, 'c', clBlue);
How to solve that ?
axrDegen
Post by axrDegen » Fri Feb 22, 2019 10:29 am
I don't really understand that source code anyway, LeftTop (a TPoint value) is set per series Mark via call "Chart.Canvas.Calculate3DPosition"
How is the 3D position (X, Y, Z) coded into a TPoint, which only has X and Y ?
So where do you finally set the Z position of each Mark?
Post by Yeray » Mon Feb 25, 2019 10:44 am
It seems to work fine for me here:
testVectorArrow2.zip
(2.17 KiB) Downloaded 111 times
The Calculate3DPosition function converts 3D coordinates to 2D coordinates to be used when custom drawing (ref here)
Calculates and returns the XY position in pixels of the XYZ 3D coordinate.
Can be used when custom drawing using 3D XYZ coordinates, either returned from the axes or not.
axrDegen
Post by axrDegen » Mon Feb 25, 2019 11:17 am
Thank you, but this doesn't work. I am finally painting the axes labels in the OnAfterDraw event like that:
    XCent := FAxesSeries.CalcXPosValue(0);
    YCent := FAxesSeries.CalcYPosValue(0);
    ZCent := aChart.Axes.Depth.CalcPosValue(0);
    XPosi := FAxesSeries.CalcXPosValue(FXAxisMax);
    YPosi := FAxesSeries.CalcYPosValue(FYAxisMax) - aChart.Canvas.TextHeight('b');
    ZPosi := aChart.Axes.Depth.CalcPosValue(FZAxisMax);
    aChart.Canvas.TextOut3D(XPosi, YCent, ZCent, 'a');
    aChart.Canvas.TextOut3D(XCent, YPosi, ZCent, 'b');
    aChart.Canvas.TextOut3D(XCent, YCent, ZPosi, 'c');
Post by Yeray » Mon Feb 25, 2019 11:39 am
That's another possibility. Does it work as you want?
axrDegen
Post by axrDegen » Mon Feb 25, 2019 12:34 pm
Yes, that works very well
Post by Yeray » Tue Feb 26, 2019 7:22 am
Great!
