Up to 60 points it's working:
![Image](https://i.ibb.co/Z2dNSG3/1.jpg)
But for example for 70 points (when labels start to overlap each other) - chart itself performs labels thinning (my function Bottom_GetAxisDrawLabel is disabled here):
![Image](https://i.ibb.co/HDWZ2Qs/2.jpg)
//max visible labels
private const Int32 maxDisplayedLabelsForBottomaAxis = 20;
List<string> _labels = new List<string>();
int _count;
var rnd = new Random();
tChart1.Zoomed += TChart1_Zoomed;
tChart1.UndoneZoom += TChart1_UndoneZoom;
_count = 4000;
for (int i = 0; i < _count; i++)
line1.Add(i, rnd.Next(5));
_labels.Add($"Point NoClue #{rnd.Next()}");
if (ShouldDrawIndex(i, 0, _count))
tChart1.Axes.Bottom.Labels.Items.Add(i, _labels[i]);
private void TChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
this.Text = $"Number of labels = {tChart1.Axes.Bottom.Labels.Items.Count}";
private void TChart1_UndoneZoom(object sender, EventArgs e)
tChart1.Axes.Bottom.Labels.Items.Clear();
private bool ShouldDrawIndex(int index, int firstVisible, int lastVisible)
if ((lastVisible - firstVisible) > maxDisplayedLabelsForBottomaAxis)
var drawEvery = ((lastVisible - 1 - firstVisible) / maxDisplayedLabelsForBottomaAxis) + 1;
return index % drawEvery == 0;
return true;
private void TChart1_Zoomed(object sender, EventArgs e)
var xvalues = line1.XValues.Value.Where((x, i) => i < _count);
var min = line1.XValues.IndexOf(xvalues.Where(x => x >= tChart1.Axes.Bottom.Minimum).First());
var max = line1.XValues.IndexOf(xvalues.Where(x => x <= tChart1.Axes.Bottom.Maximum).Last());
for (int i = min; i <= max; i++)
if(ShouldDrawIndex(i, min, max))
So we've finally returned to using Zoomed and UndoneZoom eventsChristopher wrote: ↑Tue Aug 13, 2019 7:58 amokay, well, another variation on an earlier technique seems to work in these circumstances, i.e.
You're welcome.
The Value field is public but is for internal use. If you are uncomfortable using it, you can use the more standard API calls:
List<double> xvalues = new List<double>();
xvalues.Add(line1.XValues[i]);
//var xvalues = line1.XValues.Value.Where((x, i) => i < _count);
