I have encounter the following issue after upgrading my project library from the 2016 to the latest 2023 one. My chart axis delimiter has disappeared, is there a new option to get it back?
2016 TeeChart:
2023 TeeChart:
Thank you.
Axis delimiter has disappeard with TeeChart for .Net v2023
- image-20230622-073102.png (41.84 KiB) Viewed 10099 times
- image-20230622-073109.png (47.05 KiB) Viewed 10099 times
- Guru
Re: Axis delimiter has disappeard with TeeChart for .Net v2023
If this doesn't work, could you please upload an M.R.E. as I mentioned at the end of this message.
This is usually the Visible property of the AxisPen, e.g.
tChart1.Series.Add(typeof(Bar)).FillSampleValues();
tChart1.Axes.Bottom.AxisPen.Visible = !tChart1.Axes.Bottom.AxisPen.Visible;
