I believe this question was asked many years ago but I could not retrieve anything from Search.
I need to fill the area between 2 series (e.g. Series1 and Series2) with a constraint that fill will apply only when Series1 values are smaller than Series 2 (see attached image), I tried using the available TChart tools but with no luck, any help would be mostly appreciated
Fill area between 2 series
- Annotation 2019-04-08 120016.png (5.35 KiB) Viewed 15137 times
Re: Fill area between 2 series
Check the Series Band Tool. I've just run the "All features\Welcome !\Tools\Series Band" example in the New Features demo, changed the series from Line series to HorizLine series and reassigned the second series for the tool:
I tried that, had to change both line series to Horizontal type however the result is not good.
- Annotation 2019-04-08 152955.png (4.58 KiB) Viewed 15129 times
Please, arrange a simple example project we can run as-is to reproduce the problem here.
Here is a sample app
- test.zip
- (51.92 KiB) Downloaded 886 times
I could reproduce the problem so I've added it tot he public tracker: #2182.
Note I've already fixed it.
The fix consists on modifying the TryAddCrossPoint function in TeeSeriesBandTool.pas, from this:
To this:
function TryAddCrossPoint(t:Integer; isStairs,isStairs2:Boolean):Boolean;
if result then
AddPointXY(Series.CalcXPosValue(X),Series.CalcYPosValue(Y))
end
if IsStairs then
AddPoint(Series,IsStairs,t);
if result then
if Series.YMandatory then
AddPointXY(Series.CalcXPosValue(Y),Series.CalcYPosValue(X));
end
if IsStairs then
Thank you, will give it a try
