Show Selected using 2 charts
realsol
Post by realsol » Mon Aug 14, 2017 5:42 am
Attached are two charts. When the user clicks on a month in the BarChart (January in this case), it displays that months expense categories below in a PieChart. Is there any way to color or keep the clicked bar highlighted (like when hovering over it)? This way the user always see which month is being displayed in the PieChart below.
Re: Show Selected using 2 charts
Post by Sandra » Thu Aug 17, 2017 12:12 pm
Hello realsol,
I think you can active the Hover propierty. The code below shows you how?
Chart1.Hover.Visible := Hover;
Hoping this helps you.
Thanks in advance
realsol
Post by realsol » Thu Aug 17, 2017 7:20 pm
Sandra wrote:Hello realsol,
Thanks in advance
This gave me an error on 'Hover', so I tried this in the OnSeriesClick Event:
Chart1.Hover.Visible := true;
But it still doesn't keep the bar in hover state. I know which bar they click, I just need to somehow highlight it after a user clicks it.
Post by Sandra » Fri Aug 18, 2017 11:20 am
Hello realsol,
I have made a simple code with help of MouseDown and MouseUp events, I can select a concrete bar value when I do click in it. The code I have used is below:
procedure TForm2.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
  Shift: TShiftState; X, Y: Integer);
  if avalueIndex<>-1 then
    Chart1[0].ValueColor[avalueIndex] :=aColor;
procedure TForm2.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
var valueIndex:Integer;
valueIndex:=Chart1[0].Clicked(X, Y);
   if valueIndex>-1 then
      Chart1[0].ValueColor[valueIndex] := clRed;
      avalueIndex :=  valueIndex;
procedure TForm2.FormCreate(Sender: TObject);
  Chart1.View3D:=false;
 Chart1.AddSeries(TBarSeries).FillSampleValues();
 aColor := Chart1[0].Color;
 avalueIndex:=-1;
Could you confirm us if it works in your end?
Thanks in advance
