The dashed/dotted line is not working as expected in safari browser. Please refer the attached image for the reference.
Is there any browser compatibility issue in Teechart? Please let me know how to fix this dashed line issue in all browsers.
Thanks!
Dotted/Dashed Line issue.
- chrome.png (88.06 KiB) Viewed 11093 times
- safari.png (123.32 KiB) Viewed 11092 times
Re: Dotted/Dashed Line issue.
I've published a test page here to check it on different browsers and I see the dashed lines correctly drawn in Safari 9.1.1 (11601.6.17) from an OS X El Capitan 10.11.5
I have tested using the same sample code. But, still I am facing the dashed line problem. Actually, I am using Safari v5.1 on Windows 7 OS. Please refer the attachment.
Does Teechart supports all the version of Safari browser?
- SafariDashLineIssue.jpg (87.96 KiB) Viewed 11061 times
Note Safari for Windows isn't supported by Apple any-more and the current Safari version is at v9.1. So there may be Javascript functions that weren't supported in v5.1 that are in later versions.
Ie, you can check CanIUse.
