In working with Seattle, if "Enable High-DPI" (in Project/Options/Application) is checked, Annotations' text will appear small
(it is a little hard to see here unless you compare the annotation font against the axis label font--it is smaller, but should be the same size, or see that the annotations above take up less width than the annotations below).
But if I change it so that it is unchecked, it appears normal size:
I much prefer the first image (much cleaner), but the Annotation text is too small.
Is there a way to get the annotation text to not change its size based on DPI?
Ed Dressel
Delphi Seattle: Enable High-DPI results than expected
- Advanced
Re: Delphi Seattle: Enable High-DPI results than expected
Hello Ed,
(Thanks for your patience on posting this in the wrong group).
I have attached a demo. Click in the chart to add color bands and annotations.
To see the difference, I compiled with the DPI settings checked and unchecked and renamed the EXE. I then ran the program on my Dell XPS 13. (I could not see it on my development computer).
Ed Dressel
Ed Dressel
- Selection Point 3d.zip
- (7.08 KiB) Downloaded 1787 times
Hello Ed,
We'll revise the issue and we'll tell you something asap.
No problem! I've moved it to the according forum now.TestAlways wrote:(Thanks for your patience on posting this in the wrong group).
- Advanced
I'm not sure I understand what that means. Could you clarify?Yeray wrote:We'll revise the issue...
Ed Dressel
Hi Ed,
Yes. We'll check what's wrong, we'll see if we can do something to improve that, we'll investigate where the problem comes from...TestAlways wrote:I'm not sure I understand what that means. Could you clarify?
Just checking that you could reproduce the issue?
Ed Dressel
Ed Dressel
Hello Ed,
Yes, I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1447
