How do I set Labels Increment
Dave
Post by Dave » Mon Dec 02, 2013 11:01 pm
Hi there
This is a very similar question to my previous one.
I am adding labels programmatically using C#.Net (see below)
However when I zoom-in I don't see any labels
How do I make my custom labels behave in a similar way to the default labels? ie. when you zoom-in you see labels at the new scale
TIA
int count1 = theChart.Series[0].XValues.Count;
theChart.Axes.Bottom.Labels.Items.Clear();
int z1 = 0;
while (z1 < count1)
string m = (count1 - z1).ToString();
theChart.Axes.Bottom.Labels.Items.Add(z1, m);
++z1;
Re: How do I set Labels Increment
Post by Sandra » Tue Dec 03, 2013 10:28 am
Hello Dave,
I have tried to reproduce problem using your custom labels code in a simple c# code:
      InitializeChart();
      Steema.TeeChart.Styles.Line line1 = new Line(tChart1.Chart);
      line1.FillSampleValues();
      AddCustomLabels();
     private void AddCustomLabels()
       int count1 = tChart1.Series[0].XValues.Count;
       tChart1.Axes.Bottom.Labels.Items.Clear();
       int z1 = 0;
       while (z1 < count1)
         tChart1.Axes.Bottom.Labels.Items.Add(z1, m);
         ++z1;
And Axes labels doesn't disappear for me. For this reason, I would be very grateful if you could arrange for us a simple project where the problem appears, because we can reproduce it here and try to give you a good solution.
