Unit Conversion in teechart?
FHG_AST
Post by FHG_AST » Tue Apr 28, 2009 11:14 am
Hi@All
I need to convert untis in teechart. In my database I have stored all values for heights in Meters. To convert them and display them as inches or feets I use the Delphi TField.OnGetText function. In this function the float values from the database where converted and displayed as strings in the attached control like TDBEdit.
In Teechart this doesn't work. It seems like Teechart does directly access the Field or the Dataset in the database.
Who knows how I can display the series with other units?
Post by Yeray » Tue Apr 28, 2009 11:57 am
Hi FHG_AST,
I can think in some different possibilities:
1. The best solution would be if you could use a database that wouldn't need any conversion. I mean, it would be better if you could convert your values to a new database and use this new database as your series' source.
2. You could use a series linked to your database in meters but inactive. Then you could have another series and every time you want to update it's values, search in the "source dummy series" for new values and convert them before adding to the second series.
3. You could have your series with values in meters and use the events OnGetAxisLabels and OnGetSeriesMarks (if marks are shown) to convert the labels from meters to feet.
If you need an example of some of the options or any further suggestions, please don't hesitate to let us know, give us as precise information as possible, and we'll try to help you.
FHG_AST
Post by FHG_AST » Tue Apr 28, 2009 1:49 pm
Hi Yeray.
The third option sounds for me as the most suitable because I have implemented an object (TunitConv) which parses each form for datasets and changes the onGetText function of the TFloatfields in them. So it is easy to add this functionality for the onGetAxisLabels and OnGetSeriesMarks of TSeries, I think.
If you have en example how to do this I woul be very grateful.
Post by Yeray » Tue Apr 28, 2009 2:11 pm
Hi FHG_AST,
Here is how you could do it but note that with this way, the texts won't show integers but the corresponding values of the original integers.
In the example I created a Point series and generated the events at designtime:
  Series1.FillSampleValues(5);
  Series1.Marks.Visible := True;
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
  LabelText := FloatToStr(StrToFloat(LabelText) * 3.2808399);
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
  MarkText := FloatToStr(StrToFloat(MarkText) * 3.2808399);
FHG_AST
Post by FHG_AST » Mon May 04, 2009 12:51 pm
Ok I tried to use this code but I have a problem.
I have a chart with multiple axes and each valuesource has a different unit conversion factor dependig on the field in the database.
I can get the unit conversion factor from the Tag of the field in the attached dataset. So my idea is to get the dataset from the series
var Uindex:integer;
  Uindex:=TDataset(Series.dataset).fieldbyname(Series.yValues.Valuesource).tag;
Btw. the conversion of the seriesmarks is not neccessary because it is done in the Fields OnGetText event
but series in this function is always NIL.
Post by Yeray » Tue May 05, 2009 10:52 am
Hi FHG_AST,
Looking at TeeChart Help, you can see at the OnGetAxisLabel description:
An Event is triggered for each Axis Label painted.
There are two different uses for OnGetAxisLabel:
1) Axis Labels are Values.
In this case, the Series parameter will be nil, and the ValueIndex will be -1.
2) Axis Labels are Series points.
The Series parameter will be a valid TChartSeries, and the ValueIndex will be the current Series point position.
So, the Series will be different to null only when some axis LabelStyle is set as talMark.
In your case you probably know what series are linked to each axis, so you could decide your conversion factor considering the Sender (TChartAxis), not the Series. Something like this:
var factor: double;
  factor := 1;
  if Sender = Chart1.Axes.Left then
    factor := 2
  else if Sender = Chart1.Axes.Right then
    factor := 3
  else if Sender = Chart1.Axes[6] then
    factor := 4
  else if Sender = Chart1.Axes[7] then
    factor := 5;
FHG_AST
Post by FHG_AST » Tue May 05, 2009 12:44 pm
Well it works fine if I set the lablestyle to talText.
But I habe an addition question. How can I get the axes associated with the series at runtime?
Post by Yeray » Tue May 05, 2009 1:12 pm
Hi FHG_AST,
Here it is a simple example:
uses series;
var i: Integer;
  Chart1.View3D := False;
  Chart1.Legend.Visible := false;
  for i:=0 to 3 do
    Chart1.AddSeries(TLineSeries.Create(self));
    Chart1[i].FillSampleValues(25);
  Chart1.CustomAxes.Add;
  Chart1[0].CustomVertAxis := Chart1.Axes.Left;
  Chart1[1].CustomVertAxis := Chart1.Axes.Right;
  Chart1[2].CustomVertAxis := Chart1.CustomAxes[0];
  Chart1[3].CustomVertAxis := Chart1.CustomAxes[1];
  Chart1.CustomAxes[0].PositionUnits := muPixels;
  Chart1.CustomAxes[1].PositionUnits := muPixels;
  Chart1.CustomAxes[0].PositionPercent := -50;
  Chart1.CustomAxes[1].OtherSide := true;
  Chart1.CustomAxes[1].PositionPercent := -50;
  Chart1.MarginUnits := muPixels;
  Chart1.MarginLeft := 60;
  Chart1.MarginRight := 60;
FHG_AST
Post by FHG_AST » Tue May 05, 2009 1:38 pm
Yes, I know but I need to set the title caption (including the unit) of the axis as the same of the datafield.Displaylabel of the associated Series.
This means in the TField.Displaylabel is a string like Diameter [%s] and I want to convert it into Diameter [mm] and set as the chartaxis.title.caption.
How do I get from the dataset field via TDbchart or TChartseries to the Axis associated to the TChartseries that gets its data from that field in the dataset?
Post by Yeray » Tue May 05, 2009 2:16 pm
Hi
If I understand well, you have the series and need to access to it's vertical associated axis. Something like this:
Chart1[0].GetVertAxis.Title.Caption := 'my new title';
FHG_AST
Post by FHG_AST » Wed May 06, 2009 7:53 am
Hi Yeray.
I know how to set the title caption but I need the connection from
TDatabase.TField-> TChartseries->TChartaxis
I have chart with 4 TFaslineseries and each has a customaxis. But which of them is Chart[0] and Chart[1] ... Chart[XXX].
In des Editdialog I have the Series "Verbrauch" Assigned to Vertaxis=Custom3
and on the other tab I have the data connection ti the assocuated datafield for te yvalues =Wassermenge
My starting point is the TDataset.fieldbyname("WASSERMENGE") and I need to go to the Chart1[????].GetVertAxis.Title.Caption= TField(TDataset.fieldbyname("WASSERMENGE")).Displaylabel;
The ??? is that what is if interest for me.
In this Form I can hard code it when I open the Charteditor an look at the order of the customseries. But I have a lot of different forms with other Datafields and other series and different count of them. So I want to create a parent class which parses the form for all Fields of TDatasets and then translates the associated axes.
Post by Yeray » Wed May 06, 2009 9:47 am
Hi FHG_AST,
So you need to retrieve the series' index of the series where Labels are set to 'WASSERMENGE', right? This could be done as follows:
var i, SeriesIndex: Integer;
  for i:=0 to DBChart1.SeriesCount-1 do
    if Series1.XLabelsSource = 'WASSERMENGE' then
      SeriesIndex := i;
      break;
  DBChart1[SeriesIndex].GetVertAxis.Title.Caption := 'your custom title';
FHG_AST
Post by FHG_AST » Wed May 06, 2009 11:51 am
YES!!!
Thats it. It works.
Thank you.
