TeeGofer maintenance release announcement - Build 2.6.2200.2
TeeGofer general
Locked
Post by Marc » Tue Jan 10, 2006 4:26 pm
Steema Support Central would like to inform you of the availability of the TeeGofer v2 update to support Visual Studio.NET 2005. The update has been built in Framework 2.0 to support reflection of Framework 2.0 assemblies. You can access the update via the customer download page at:
http://www.steema.com/downloads/client_access.html
Release notes may be viewed here:
http://www.steema.com/files/public/TeeG ... elease.txt
Diego
Post by Diego » Sat Feb 18, 2006 11:04 pm
Hi, the TeeGofer for VS.2005 throws the following errors after importing my assembly:
System.NullReferenceException: Object reference not set to an instance of an object.
at TeeGofer.MetaViewerForm.DiscoverParamFileName(Type element)
at TeeGofer.MetaViewerForm.GetTypeDeclaration(Type t)
at TeeGofer.MetaViewerForm.PopulateTypes(Type[] arTypes, TreeNode assemblyNode, Int32 moduleProgressRange)
at TeeGofer.MetaViewerForm.TeeGofer(Int32 moduleProgressRange)
at TeeGofer.MetaViewerForm.DisplayMetaData(Int32 moduleProgressRange)
at TeeGofer.MetaViewerForm.BuildProject(Boolean isNew)
at TeeGofer.MetaViewerForm.LoadNewProject()
at TeeGofer.MetaViewerForm.menuItem2_Click(Object sender, EventArgs e)
at TeeGofer.MetaViewerForm.toolBar1_ButtonClick(Object sender, ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.OnButtonClick(ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.WmReflectCommand(Message& m)
at System.Windows.Forms.ToolBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
Mike Jones
Problem in January of 2007 Release.
Post by Mike Jones » Mon Feb 05, 2007 6:42 pm
I am seeing a similar problem when trying to open an VS 2005 assembly
at TeeGofer.MetaViewerForm.GetMethodInfo(MemberInfo memberInfo)
at TeeGofer.MetaViewerForm.GetMemberDeclaration(MemberInfo memberInfo)
at TeeGofer.MetaViewerForm.AddOverloadMemberNode(MemberInfo member, TreeNodeCollection treeNodeCollection, Int32 overloadIndex)
at TeeGofer.MetaViewerForm.AddOverloads(MemberInfoNode memberInfoNode, MemberInfo member, TreeNodeCollection treeNodeCollection, NodeObject lObj, Int32 overloadCount)
at TeeGofer.MetaViewerForm.PopulateMembers(TreeNodeCollection treeNodeCollection, ArrayList overLoadList, TypeNode parentNode, ArrayList ctorOverloadList, ArrayList sortedList, Type t)
Post by Narcís » Tue Feb 06, 2007 11:37 am
Hi Mike,
We just posted a new build at the client area. Can you please check if this solves the issue?
Locked
