TeeGopher crashes when I attempt to import the XML summary
TeeGofer general
Locked
Brian B.
Post by Brian B. » Thu Aug 05, 2004 7:06 pm
I'm not sure why, but TeeGopher seems to crash when I import the XML summary. My project is fairly simple. It contains a single assembly (mainly WinForm controls and other classes used to build UIs) and a few custom topics. When this happens, I remove the assembly and then add it back in and it seems to work ok. This fix won't work once I add the rest of the assemblies to the project.
Do you have any idea why this might be happening? I've included the exception information below.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at TeeGofer.MetaViewerForm.SaveExistingNodeInfo(Hashtable tmpNodeObjHashTable, Int32 Count)
at TeeGofer.MetaViewerForm.RefreshProjectContents()
at TeeGofer.MetaViewerForm.menuItem26_Click(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
TeeGofer
Assembly Version: 2.5.0.5
Win32 Version: 2.5.0.5
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/TeeGofer.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/AxInterop.SHDocVw.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
Interop.SHDocVw
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/Interop.SHDocVw.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Post by Christopher » Mon Aug 16, 2004 12:53 pm
Hi Brian,
Sorry for the delay .. I've been off work for a couple of weeks.
Mmm, nothing immediately springs to mind here; can you reproduce this behaviour using the SteemaSimpleControl.dll & xml shipped with TeeGofer?
Thank you!
http://groups.google.com
http://codenewsfast.com/
Locked
