Cursors
TeeChart Beta versions
history
Cursors
Post by history » Mon Apr 13, 2009 5:14 pm
Are there any changes in version 4 to address cursor performance?
Post by Narcís » Tue Apr 14, 2009 10:10 am
Hi history,
Are you using FastCursor=true?
history
Post by history » Tue Apr 14, 2009 2:14 pm
Post by Narcís » Wed Apr 15, 2009 1:50 pm
Hi history,
Thanks for the information.
while the regular cursor is choppy in movement when there are a large number of points due to the painting
Nothing else has been done on that field. That's why FastCursor property was implemented.
One of the issues with fastcursor is that you may want to display information on the chart as the cursor is changing. With TeeChart you seem to be only able to paint all the screen and not a portion of the screen.
Yes, this works fine with our current v4 sources and using code below. You can see that only the annotation tool is being repainted if you set FastCursor to false.
			InitializeChart();
		private Steema.TeeChart.Tools.Annotation anno;
		private Rectangle r1;
			tChart1.Graphics3D.BufferStyle = Steema.TeeChart.Drawing.BufferStyle.DoubleBuffer;
			tChart1.Series.Add(typeof(Steema.TeeChart.Styles.Line));
			tChart1[0].FillSampleValues(10000);
			Steema.TeeChart.Tools.CursorTool cursor;
			tChart1.Tools.Add(cursor = new Steema.TeeChart.Tools.CursorTool());
			cursor.Style = Steema.TeeChart.Tools.CursorToolStyles.Vertical;
			cursor.FollowMouse = true;
			cursor.FastCursor = true; //try false
			cursor.Change += new Steema.TeeChart.Tools.CursorChangeEventHandler(cursor_Change);
			tChart1.Tools.Add(anno = new Steema.TeeChart.Tools.Annotation());
			anno.AutoSize = false;
			anno.Top = 10;
			anno.Left = 10;
			anno.Height = 20;
			anno.Width = 110;
			r1 = anno.Shape.ShapeBounds;
			tChart1.AutoRepaint = false;
		void cursor_Change(object sender, Steema.TeeChart.Tools.CursorChangeEventArgs e)
			anno.Text = e.XValue.ToString();
			tChart1.Invalidate(r1);
Post by Narcís » Wed Apr 15, 2009 2:17 pm
Hi history,
In the example above you may also be interested in implementing cursor's Change event as shown below when FastCursor=false.
		private Rectangle oldRect;
			Rectangle rect = tChart1.Chart.ChartRect;
			Steema.TeeChart.Tools.CursorTool cursor = (Steema.TeeChart.Tools.CursorTool)sender;
			int cursorPos = tChart1.Axes.Bottom.CalcPosValue(e.XValue - cursor.Pen.Width/2);
			Rectangle r2 = new Rectangle(cursorPos, rect.Top, cursor.Pen.Width, rect.Height);
			if (oldRect!=null) tChart1.Invalidate(oldRect);
			tChart1.Invalidate(r2);
			oldRect = r2;
