Make node visible in TTree
Lenfors
Post by Lenfors » Mon Oct 21, 2013 2:23 pm
Hello!
I have a TTree with a lot of nodes in it. How can I programatically make a certain node to be visible in the Tree? (Inside the visible area of the tree)
Best regards, Mikael
Re: Make node visible in TTree
Post by Yeray » Wed Oct 23, 2013 3:05 pm
Hi Mikael,
Can't you do this with a TTreeNodeShape?
TreeNodeShape1.Visible:=true;
Lenfors
Post by Lenfors » Wed Oct 23, 2013 7:12 pm
Sorry, I explained badly... In my TTree I have a tree structure displayed, like in Explorer. Now I want my TTree to scrool so that my current node becomes visible.
best regards, Mikael
Post by Yeray » Fri Oct 25, 2013 1:33 pm
Hi Mikael,
In the following example, we have a root node with a hundred childs.
If you want you can scroll down dragging the Tree with the right mouse button, or you can use the scrollbar for the same.
var i: Integer;
    TreeNodeShape1: TTreeNodeShape;
  TreeNodeShape1:=Tree1.AddRoot('Root');
  TreeNodeShape1.Expanded:=true;
  for i:=0 to 100 do
    TreeNodeShape1.AddChild('Child ' + IntToStr(TreeNodeShape1.Children.Count+1));
If you are looking for a function to force the scroll to a determined child by code, you can use View3DOptions.VertOffset:
var i: Integer;
  for i:=0 to 100 do
  TreeNodeShape1.Children[49].Selected:=true;
  Tree1.Draw;
  Tree1.View3DOptions.VertOffset:=-TreeNodeShape1.Children[49].Y0;
