How could i enlarge distance between dots in gridlines
glikoz
Post by glikoz » Thu May 10, 2007 12:23 pm
I have vertical grid lines on Bottom Axis ..
How could i enlarge distance between dots in gridlines ?
Is it possible?
Post by Narcís » Thu May 10, 2007 1:30 pm
Hi glikoz,
You can set axes grid style like this:
			tChart1.Axes.Bottom.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dash;
If none of defined styles fits your needs you can also use DashPattern as shown here.
glikoz
Post by glikoz » Thu May 10, 2007 3:40 pm
I tried to redound space between two dashes ..Although i try different pattern
i couldn't change space between two dashes. ..
Post by Narcís » Fri May 11, 2007 9:57 am
Hi glikoz,
Have you tried using DashPattern as in the example I posted at the thread I pointed you?
Please notice that this features was implemented in one of latest maintenance releases so this will only be supported Build 2.0.2546.16098/9 from 21st December 2006 or newer versions.
glikoz
Post by glikoz » Fri May 11, 2007 10:54 am
Ok it seems work...
Thx..
