Loading a template file creates problems for a tower series.
VH1
Post by VH1 » Mon Jan 23, 2006 5:22 pm
1.1.2179.21092
This article relates to
http://www.teechart.net/support/viewtopic.php?t=2961
and
http://www.teechart.net/support/viewtopic.php?t=3376
To recreate...
In designer...
Add a teechart to a form.
Add a commander bar and set the chart property.
Run...
Add a tower series
Add a random data source (just select random and apply)
Click a button which does the following operation...
private void button1_Click(object sender, System.EventArgs e)
string path = string.Format("{0}\\Charts", Application.StartupPath);
// Determine whether the directory exists.
if(!System.IO.Directory.Exists(path))
// Try to create the directory.
System.IO.DirectoryInfo di = System.IO.Directory.CreateDirectory(path);
string strChartTemplatePath = Application.StartupPath + @"\Charts\01.Ten";
// Store the existing chart.
System.IO.FileStream fsCreate = null;
if(strChartTemplatePath != null)
// Overwrite the existing file
fsCreate = new System.IO.FileStream(strChartTemplatePath,System.IO.FileMode.Create);
this.tChart1.Export.Template.Save(fsCreate);
if(fsCreate != null)
fsCreate.Close();
FileStream fsOpen = null;
fsOpen = new System.IO.FileStream(strChartTemplatePath, System.IO.FileMode.Open);
this.tChart1.Import.Template.Load(fsOpen);
if(fsOpen != null)
fsOpen.Close();
this.commander1.Chart = this.tChart1;
Conclusion....
A red bar appears as the first XYZ value oon the chart.
Vaughan
