What are the series size limitations of a ColorGrid?
MTB
Post by MTB » Tue Jan 27, 2004 5:28 pm
What is the maximum length of an x-axis one can use with the ColorGrid? I have been using ColorGrids without any problems, until yesterday when I charted a series with about 20,000 points. This causes a runtime exception.
I have not yet investigated further. I wanted to first find out if there is a known limit I am hitting. If so, is there an alternative to the ColorGrid?
In my application, the ColorGrid is used to create a graphic that is similar to a horizontal stacked bar. However, each x-axis data point is assigned a particular color. Is there any other approach (besides the ColorGrid) in TeeChart that would be better for producing a horizontal row of colors with the ability to set a color for each x-axis point based on a y or z value?
Thanks!
BTW, the new annotation callout is really cool! There are many nice new features in the last release.
Marjan
Post by Marjan » Thu Jan 29, 2004 5:11 pm
Hi.
In the latest version any Custom3DGrid series size is limited to 2000x2000 cells (2000 points in x direction, 2000 points in z direction). This is defined in Custom3DGrid.cs as:
    private const int MaxAllowedCells=2000; /* max 2000 x 2000 cells */
If you have TeeChart sources, you could change this value to larger number (but we don't recommend it).
Try replacing group of points in x and z direftion with one point represending the average value. Or use another approach to reduce actual number of points you're adding to series.
Marjan Slatinek,
