Adding multiple points after Template.Load crashes
Posted: Tue Apr 16, 2024 7:09 pm
by 15696632
Visual Studio 2022
Target framework .NET 6.0
Steema.TeeChart.net Version 4.2024.4.12
After a template is imported using the Load Command, it crashes after adding more the one point to the series. It crashes in 2nd LoadData. This example works if only 1 point is added.
Steema.TeeChart.TChart tChart1;
tChart1 = new Steema.TeeChart.TChart();
this.Controls.Add(tChart1);
tChart1.Axes.Bottom.Visible = true;
tChart1.Axes.Left.Visible = true;
tChart1.Axes.Right.Visible = false;
Line line = new Line();
tChart1.Chart.Series.Add(line);
LoadData();
TemplateExport template = tChart1.Export.Template;
template.IncludeData = false;
tChart1.Export.Template.Save("template.json");
tChart1.Import.Template.Load("template.json");
LoadData();
private void LoadData()
var line = tChart1.Chart.Series[0];
line.Add(1, 1);
line.Add(2, 2);
line.Add(3, 3);
Re: Adding multiple points after Template.Load crashes
Posted: Thu Apr 18, 2024 8:10 am
by edu
Thank you for the issue report. We are investigating possible causes.
Posted: Tue May 14, 2024 5:51 pm
by 15696632
Any update on this issue?
Posted: Wed May 15, 2024 7:13 am
by edu
Hi, a fix has been made that will be included with the next update, due for imminent release this week.
Edu
Posted: Wed May 15, 2024 12:39 pm
by 15696632
Thanks for letting me know.
