Checking On SubAxes Visible Property Causes Exception
Kris C
Post by Kris C » Wed Jul 05, 2023 6:46 pm
Please extract, open and run the attached sample project.
Click the Optins Button
Go to Chart -> Axes->SubAxes
Click on Visible
When you turn the Visible property on, you will get:
06/21/2023 08:39:04.13 System.NullReferenceException: Object reference not set to an instance of an object.
at Steema.TeeChart.Editors.AxisEditor.cbVisible_CheckedChanged(Object sender, EventArgs e)
Kind Regards,
Kris Culin
Bentley Systems, Inc.
TeeChartNET60.zip
Sample Project
(8.32 KiB) Downloaded 674 times
Re: Checking On SubAxes Visible Property Causes Exception
Post by Christopher » Mon Jul 10, 2023 8:47 am
thank you for reporting this issue to us. We have added it to our issue tracking software with id=2620, and we attach the git diff as 'diff.md' within 'diff.zip' so you can keep your sources up to date.
diff.zip
(681 Bytes) Downloaded 810 times
Kris C
Post by Kris C » Mon Jul 10, 2023 10:11 am
Hi Christopher,
Thank you for the fix and the diff so I can keep the source up-to-date.
Kind Regards,
Kris Culin
