3D polygon mesh volume calculation
bairog
Re: 3D polygon mesh volume calculation
Post by bairog » Sun Mar 05, 2023 10:13 am
The object for which I need to calculate the volume looks something like this:
For this object I have a set of points and set of triangular faces. But that faces doesn't form a closed watertight solid (that is a feature of my 3D scanner) - just look at the object "back":
Because my object is not closed I cannot use most of triangle-based solutions.
geometry4Sharp library is not an option for the same reason (as it also needs triangles to define a closed region).
But what If instead Points3D series I will try to use TriSurface series (and feed my object's points to it)? Is there a way to enumerate triangles that series constists of (as I don't see any suitable member)?
Post by Christopher » Thu Mar 09, 2023 9:00 am
The issue is that there isn't a list of triangles per se, basically because of the immediate mode canvas that TeeChart renders to (GDI+). If it rendered to a retained mode canvas, such as OpenGL or Direct3D, then we'd have an array of triangles to which we would apply matrices for translation and rotation and so on, but in our case we have no such array as we calculate the triangles and position them in a single algorithm that is ripped down on every repaint.
