Remove text after drawing 2D text on canvas
Sharkann
Post by Sharkann » Thu Aug 11, 2022 2:16 pm
I wanted to add some custom text on a curve, depending on the points values.
I made a rocedure called in the afterdraw event of the chart, as follows :
Public Sub label_water_valves(s As Steema.TeeChart.Styles.Series, e As Steema.TeeChart.Drawing.Graphics3DGdiPlus)
        Dim X, Y, old As Double
        Dim te = ""
        Dim res As Integer
        old = -1
        For i As Integer = 0 To s.XValues.Count - 1
            If s.YValues(i) > 0 And s.YValues(i) <> old Then
                X = Main.TChart1.Axes.Bottom.CalcXPosValue(s.XValues(i))
                Y = Main.TChart1.Axes.Left.CalcYPosValue(s.YValues(i))
                res = HexStringToBinary(s.YValues(i))
                If res And 4 Then te = te & "LP"
                If res And 16 Then te = te & vbCrLf & "HP"
                If res And 64 Then te = te & vbCrLf & "RSV"
                e.TextOut(X, Y, te)
                te = ""
                old = s.YValues(i)
            End If
        Next
s is the Serie I want to track.
Problem : once the text is drawn (works well), is there any way to hide it or remove it ?
In some part of my project, the user can hide/show curves. If I hide the series "s", the text remains on the graph...
The part 13 of the tutorial explains how to draw things on the graph, but not how to erase them.
Any idea ?
Re: Remove text after drawing 2D text on canvas
Post by Marc » Fri Aug 12, 2022 7:57 am
Everything in OnAfterDraw is called every time the Chart is rendered. If you put boolean conditions in there, like:
if myCondition
  runCustomDrawCode
end if
then you can control i t being called by setting the condition to true or false ... Calling Chart.Repaint causes the chart to render and according to whether you have set the condition true/false the custom code will run or not; that way, effectively, removing any custom content if not required.
Sharkann
Post by Sharkann » Tue Aug 30, 2022 7:16 am
Hi !
Working fine ! Thanks for the answer.
Sharkann
