How to draw multiple line without adding series?
Posted: Tue Dec 17, 2019 1:48 am
by 16082909
For example, I have a sales chart by item with teechart.
- before.jpg (143.94 KiB) Viewed 14917 times
I want to add break-even point line on 450.
- after.jpg (150.85 KiB) Viewed 14917 times
How can I implement it? I think it would be good if you give me a sample
Thank you.
Re: How to draw multiple line without adding series?
Posted: Wed Dec 18, 2019 7:34 am
by Christopher
goodsj wrote: ↑Tue Dec 17, 2019 1:48 am
Of course - you can find the sample I refer to below in the
TeeChart for .NET C# Windows Forms examples repo under the 'Feature Demo' folder. The sample shows TeeChart's canvas events which allow you to draw lines, shapes, text and images at any point of the chart at different times of its painting routine:
- TeeChartNetExamples_Ek94xF71VG.png (187.6 KiB) Viewed 14896 times
Posted: Fri Dec 20, 2019 2:36 am
by 16082909
Thanks for answering.
I could draw line with Graphics3D, Point.
but, I couldn't set 450 its line position dynamically regardless of chart size.
Posted: Fri Dec 20, 2019 9:47 am
by Christopher
goodsj wrote: ↑Fri Dec 20, 2019 2:36 am
You can fix the point by getting the Axis to calculate the pixel value of the Axis value for you, e.g.
private void TChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
var yVal = tChart1.Axes.Left.CalcPosValue(450);
g.Pen.Color = Color.Red;
g.HorizontalLine(tChart1.Chart.ChartRect.Left, tChart1.Chart.ChartRect.Right, yVal);
Posted: Mon Dec 23, 2019 7:04 am
by 16082909
Thanks to you, we solved the problem.
