I am trying to use your newest TeeChart.WinForm.dll.
There is a problem when setting the Theme from source code or from the GUI Chart Option
System.ArgumentNullException: Value cannot be null. (Parameter 'serializationStream')
at System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, Boolean check)
at Steema.TeeChart.Import.TemplateImport.Load(Stream stream)
at Steema.TeeChart.Themes.Theme.ApplyFromResource(Chart Dest, String ResourceName)
at Steema.TeeChart.Themes.OperaTheme.Apply()
at Steema.TeeChart.Chart.(ThemeType )
at Steema.TeeChart.TChart.set_CurrentTheme(ThemeType value)
The same source code is working for the older TeeChart version.
Exception when changing Theme
- Guru
Re: Exception when changing Theme
Thank you for reporting this to us. I have added it to our issue-tracking software with id=2260 - as you can see, this issue has already been fixed, and this fix will become available shortly in an upcoming NuGet release.
| Christopher Ireland / Development & Support Steema Software Avinguda Montilivi 33, 17003 Girona, Catalonia Tel: 34 972 218 797 http://www.steema.com |
| Instructions - How to post in this forum |
