Changing line series color in runtime is not working
bairog
Post by bairog » Wed Aug 21, 2019 8:59 am
I've faced a strange issue while changing line series color in runtime.
I'm using tChart1_ClickLegend event to show ColorPickerDialog where user can select a color for a clicked line and it's points:
private void tChart1_ClickLegend(object sender, MouseEventArgs e)
            if (e.Button == MouseButtons.Left)
                var seriesInLegend = tChart1.Series[tChart1.Legend.Clicked(e.X, e.Y)] as Line;
                colorDialog1.Color = seriesInLegend.Pointer.Color;
                if (colorDialog1.ShowDialog() == DialogResult.OK)
                    lineEquivalentData.Color = colorDialog1.Color;
                    lineEquivalentData.Pointer.Color = colorDialog1.Color;
And it's working unpredictable - sometimes changing only points color, sometimes changing nothing:
On that screenshots I'm trying to change second (dark green) line color. As you can see - series color in legend is correct in both situations.
I was unable to reproduce issue in supersimple test app, so I've shorten my code where I've faced this problem. I've uploaded it here
Re: Changing line series color in runtime is not working
Post by Christopher » Wed Aug 21, 2019 3:07 pm
That's because you're adding in point colors to your series:
          lineActualData.Add(i, Values[i].ActualValue, Values[i].FlightDate.ToString(dateTimeMask) + " " + Values[i].FlightShift + " " + Values[i].FlightNum, lineActualData.Color);
          lineEquivalentData.Add(i, Values[i].EquivalentValue, Values[i].FlightDate.ToString(dateTimeMask) + " " + Values[i].FlightShift + " " + Values[i].FlightNum, lineEquivalentData.Color);
Adding in point colors (the last parameter of the Add function) means that there is no series color. To resolve this, either:
1) remove the last parameter of the Add function
2) change all the point colors, i.e.
                    for (int i = 0; i < lineEquivalentData.Count; i++)
                      lineEquivalentData[i].Color = colorDialog1.Color;
bairog
Post by bairog » Thu Aug 22, 2019 5:41 am
Now I'm using the following code (points >=6 should be always Gold, points >=8 should be always Tomato):
using System;
using System.Drawing;
using System.Windows.Forms;
namespace TeeChartColorTest
            //line1.Color = line1.Pointer.Color = Color.Blue;
            var rnd = new Random();
            int currentValue;
            for (int i = 0; i < 20; i++)
                currentValue = rnd.Next(11);
                if (currentValue >=8)
                    line1.Add(i, currentValue, i.ToString(), Color.Tomato);
                    if (currentValue >= 6)
                    line1.Add(i, currentValue, i.ToString(), Color.Gold);
                    line1.Add(i, currentValue, i.ToString(), line1.Pointer.Color);
                colorDialog1.Color = line1.Color;
                    for (int i = 0; i < line1.Count; i++)
                    //change point colors (except for Tomato and Gold)
                        if (line1[i].Color == line1.Color)
                            line1[i].Color = colorDialog1.Color;
                    line1.Color = line1.Pointer.Color = colorDialog1.Color;
With commented line it works as expected:
Changing color to cyan:
But when I uncomment that line (where I manually change line color to Blue) - all point are Blue despite I'm setting every point color explicitly in the Add function:
P.S.
1) As far as I understand Steema.TeeChart.Styles.Line.Color is default color for line, Steema.TeeChart.Styles.Line.Pointer.Color is default color for line points, line1.Color (Steema.TeeChart.Styles.SeriesXYPoint.Color) is color of a given point (in case I explicitly set color in the last parameter of the Add function).
But what Steema.TeeChart.Styles.Line.Brush.Color, Steema.TeeChart.Styles.Line.Brush.ForegroundColor and Steema.TeeChart.Styles.Line.LinePen.Color stands for? Do I need to set them when I change line color via ColorDialog?
2) I still have some chart print requirements that are critical for our software (access to zoom property for printer and dashed grid poor print quality). I've asked about current progress here, but got no answer.
Post by Christopher » Thu Aug 22, 2019 7:34 am
In this scenario there is no need to complicate matters with the series color at all, i.e.
        private readonly TChart tChart1 = new TChart();
        private readonly Line line1 = new Line();
        private readonly ColorDialog colorDialog1 = new ColorDialog();
        private Color oldColor;
            splitContainer1.Panel2.Controls.Add(tChart1);
            InitializeChart();
            tChart1.Series.Add(line1);
            line1.Pointer.Visible = true;
            tChart1.Legend.LegendStyle = LegendStyles.Series;
            tChart1.ClickLegend += TChart1_ClickLegend;
            oldColor = line1.Pointer.Color = Color.Blue;
            Random rnd = new Random();
            int currentValue;
                if (currentValue >= 8)
                    line1.Add(i, currentValue, i.ToString(), oldColor);
        private void TChart1_ClickLegend(object sender, MouseEventArgs e)
                        if (line1[i].Color == oldColor)
                    oldColor = colorDialog1.Color;
No, there is no progress to report.
bairog
Post by bairog » Thu Aug 22, 2019 8:02 am
With your code all points are Blue (some of them should be Tomato or Gold as the corresponding lines are):
Sad to hear. Hope something will change because it's critical requirement for our software.
Post by Christopher » Thu Aug 22, 2019 8:11 am
Ah, so you don't want all the Pointers to be of the same color? In which case, change the following line:
to this:
oldColor = Color.Blue;
bairog
Post by bairog » Thu Aug 22, 2019 9:12 am
I supposed it is possible without saving current line color without separate variable..
Thank you, it's working.
