Howto set axis title posistion to the end of the axis?
bairog
Post by bairog » Fri Jan 11, 2019 9:37 am
Hello.
I'm using TeeChart Pro 4.2018.12.17.
As far as I can see I cannot set axis title position via TeeChart Editor:
By default it is located in the middle of the axis (to the left of labels in case of left axis and below labels in case of bottom axis):
But I want it to be at the end of axis (in a row with labels): above "1.9" label for the left axis and to the right of "04.04.2018/1/1" label for the bottom axis.
How can I do this?
Thank you.
Re: Howto set axis title posistion to the end of the axis?
Post by Christopher » Mon Jan 14, 2019 8:20 am
How can I do this?
One way would be draw your custom text directly to the Chart, e.g.
			Bar bar = new Bar(tChart1.Chart);
			bar.FillSampleValues();
			tChart1.AfterDraw += TChart1_AfterDraw1;
		private void TChart1_AfterDraw1(object sender, Graphics3D g)
			Rectangle leftRect = tChart1.Axes.Left.AxisRect();
			string leftTitle = "left title";
			g.TextOut(leftRect.X - Utils.Round(g.TextWidth(leftTitle)), leftRect.Y, leftTitle);
			Rectangle bottomRect = tChart1.Axes.Bottom.AxisRect();
			string bottomTitle = "bottom title";
			g.TextOut((bottomRect.X + bottomRect.Width) - Utils.Round(g.TextWidth(bottomTitle)), bottomRect.Y, bottomTitle);
bairog
Post by bairog » Mon Jan 14, 2019 1:37 pm
  1. I've slightly modified your code to make axis title be above all axis labels and to respect tChart1.Axis.Left.Title.Font setting (which is Calibri, 12pt, Bold in my case):
    g.TextOut((tChart1.Axis.Left.Title.Font, bottomRect.X + bottomRect.Width) - Utils.Round(g.TextWidth(bottomTitle)), bottomRect.Y - 15, bottomTitle);
    Looks like that approach ignores the fact that left axis title font is bold:
  2. Just interesting - why do you use Utils.Round(g.TextWidth(bottomTitle)) instead of Math.Round(g.TextWidth(bottomTitle))?
Post by Christopher » Mon Jan 14, 2019 3:06 pm
You can rectify this by setting the Font properties in the AfterDraw event, e.g.
			g.Font.Bold = true;
			g.Font.Name = "Calibri";
			g.Font.Size = 12;
Using Math.Round would mean having to code an additional cast to Int32, e.g.
g.TextOut(leftRect.X - (int)Math.Round(g.TextWidth(leftTitle)), leftRect.Y, leftTitle);
Utils.Round is simply a little sugar to save having to type out those extra five characters :)
bairog
Post by bairog » Tue Jan 15, 2019 4:05 pm
Thx, it's working now.
