TeeChart Panel Image
Mr.Hu_NotProSupport
Post by Mr.Hu_NotProSupport » Sat Oct 08, 2016 9:22 am
When I use the code to specify the background of the TeeChart figure, why are specified after the black, where the settings are wrong? In addition to the background image with what method to adjust the transparency?
Dim St As String
Dim resources As System.ComponentModel.ComponentResourceManager = New System.ComponentModel.ComponentResourceManager(GetType(Form3))
OpenFileDialog1.InitialDirectory = "c:\"
OpenFileDialog1.Title = ("选择一个图片")
OpenFileDialog1.Filter = "所有合法图片|(*.bmp;*.jpg;*.gif;*.png)|位图档 (*.bmp)|*.bmp|JEPG文件 (*.jpg)|*.jpg|GIF文件 (*.gif)|*.gif|PNG文件 (*.png)|*.png|所有文件 (*.*)|*.*"
OpenFileDialog1.FilterIndex = 1
OpenFileDialog1.RestoreDirectory = True
If OpenFileDialog1.ShowDialog() = DialogResult.OK Then
St = OpenFileDialog1.FileName
If IsNothing(St) = False Then
Me.TChart1.Panel.Brush.Gradient.Visible = False
Me.TChart1.Panel.Brush.Image = CType(resources.GetObject(St), System.Drawing.Image)
Me.TChart1.Panel.Brush.ImageMode = Steema.TeeChart.Drawing.ImageMode.Center
Me.TChart1.Panel.Brush.ImageTransparent = True
Me.TChart1.Panel.Image = CType(resources.GetObject(St), System.Drawing.Image)
Me.TChart1.Panel.ImageMode = Steema.TeeChart.Drawing.ImageMode.Center
Me.TChart1.Panel.ImageTransparent = True
End If
End If
Re: TeeChart Panel Image
Post by Christopher » Mon Oct 10, 2016 9:41 am
This works for me here:
  Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
    InitializeChart()
  Sub InitializeChart()
    Dim St As String
    Dim resources As System.ComponentModel.ComponentResourceManager = New System.ComponentModel.ComponentResourceManager(GetType(Form1))
        Me.TChart1.Panel.Gradient.Visible = False
        Me.TChart1.Panel.Image = ImageList1.Images(Path.GetFileName(St))
        Me.TChart1.Panel.ImageMode = Steema.TeeChart.Drawing.ImageMode.Stretch
      End If
    End If
