Disable zoom & move
user2016
Disable zoom & move
Post by user2016 » Mon Aug 01, 2016 4:11 am
Hi there, I would like to disable zoom and move by default and only enable it when enable the function when user click from ChartController.
The old codes used to be Zoom.Allow which I couldn't find the options. I have tried tChart.Zoom.Active = false; and tChart.Panning.Allow = Steema.TeeChart.ScrollModes.None;
Both codes doesn't work.
Re: Disable zoom & move
Post by Sandra » Mon Aug 01, 2016 10:20 am
Hello user2016,
I would like suggest you use Zoom Directions to disable the Zoom and Panning. Allow to disable the Scroll. The code below works in my end:
            tChart1.Zoom.Direction = ZoomDirections.None;
            tChart1.Panning.Allow = ScrollModes.None;
Hoping this helps you
Thanks in advance
user2016
Post by user2016 » Wed Aug 03, 2016 4:01 am
Hi Sandra,
Thanks for the suggestion, it works!
