Print asp.net chart when TempChart is set to Session
Sigma nBiT AB
Post by Sigma nBiT AB » Mon Dec 15, 2003 9:58 am
Hi
I have an aps.net application with a chart. The TempChart property on the
chart is set to "SESSION".
The chart is created by the following code (and a file GetChart.aspx):
Private Sub Page_Load(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles MyBase.Load
Dim ch1 As Steema.TeeChart.Chart = WebChart1.Chart
Dim tmpChart As System.IO.MemoryStream = New System.IO.MemoryStream
If Session("ch1") Is Nothing Then
series.FillSampleValues(5)
ch1.Series.Add(series)
' export Chart to a MemoryStream template
ch1.Export.Template.Save(tmpChart)
' save template to a Session variable
Session.Add("ch1", tmpChart)
Else
' retrieve the session stored Chart
tmpChart = DirectCast(Session("ch1"), System.IO.MemoryStream)
' set the Stream position to 0 as the last read/write
' will have moved the position to the end of the stream
tmpChart.Position = 0
' import saved Chart
ch1.Import.Template.Load(tmpChart)
End If
'ch1.Series(0).Marks.Style =
Steema.TeeChart.Styles.MarksStyles.Label
ch1.Series(0).Marks.Color = Color.White
GetChart.aspx looks like:
Dim chartName As String = Request.QueryString("Chart")
If Not Session(chartName) Is Nothing Then
Dim chartStream As System.IO.MemoryStream = New
System.IO.MemoryStream '
chartStream = DirectCast(Session(chartName),
Response.OutputStream.Write(chartStream.ToArray, 0,
chartStream.Length)
chartStream.Close()
Session.Remove(chartName)
End If
The chart is generated as it should (looks good on the screen) but when
the webpage is printed, only a big red X is printed where the chart should
be located.
If the TempChart property on the chart is set to "FILE" the print
operation is working.
My question to you is therefore:
What should I do to get print to work when TempChart is set to SESSION?
I have tried to add the following code to GetChart.aspx (but it did not help):
Response.ContentType = "image/gif"
Best regards
Göran, Sigma nBiT AB Sweden
Sigma nBiT AB
Post by Sigma nBiT AB » Tue Dec 16, 2003 12:25 pm
I have found a solution to the problem described above:
Remove the following line from Load method in GetChart.aspx:
chartStream.Close()!
Print will now work as you intended!
The method will then look as:
Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim chartStream As System.IO.MemoryStream = New System.IO.MemoryStream
chartStream = DirectCast(Session(chartName), System.IO.MemoryStream)
Response.ContentType = "image/png"
Response.AppendHeader("Content-Disposition", "inline; filename=prognos.png")
Response.OutputStream.Write(chartStream.ToArray, 0, chartStream.Length)
Response.End()
End If
Best regards
Göran Arvidsson Sigma nBiT AB
