How Do I import .Tee file?
Dave
Post by Dave » Fri Jul 27, 2012 9:24 am
We are trying to load a file called data.tee
Ive read tutorial 9
http://www.steema.com/files/public/teec ... #TeeFormat
This isn't helping because getImport() isnt recognised by the compiler.
Ive tried the following
Chart newChart = tChart1.Import.Template.Load("data.tee");
but get the following exception
"The input stream is not a valid binary format"
We are using TeeChart version 3.5.3187.15585 and C#.NET
Can anyone help? Thanks
Re: How Do I import .Tee file?
Post by Narcís » Fri Jul 27, 2012 9:36 am
Hi Dave,
This is a TeeChart Java tutorial. In .NET you should do as explained in tutorial 12. Tutorials can be found at TeeChart's program group.
Where did you got that *.tee file from? .tee files are generated with TeeChart ActiveX or VCL versions. NET version generates .ten files. Unfortunately both files format is not compatible. We have a test tool for converting .tee files to .ten. If you confirm that's what you need we could give you access to that tool.
