Filled Contours. Does It Work?
Dave
Post by Dave » Tue Dec 06, 2011 11:18 am
Hi there
Currently we use the contour chart and it works well .However we'd like to be able to fill the contours with different colours depending on the value. I understand this function was under development a while back. Does anyone know if this function has been implemented yet.
FYI. Our .NET TeeChart version is version 3
Re: Filled Contours. Does It Work?
Post by Sandra » Tue Dec 06, 2011 1:15 pm
Hello Dave,
Ok. I can check next code in last version 2011 of TeeChart.Net and seems that ColoEach works fine:
            Steema.TeeChart.Styles.Contour Contour1 = new Steema.TeeChart.Styles.Contour(tChart1.Chart);
            Contour1.FillSampleValues();
            Contour1.FillLevels = true;
            Contour1.ColorEach=true;
            tChart1.Draw();
But, previous code doesn't work in last version 3. The only solution as you have, if you use version 3, is set property UsesColorRange = false and set UsesPalette property = true as do in next code:
            Contour1.UsePalette = true;
            Contour1.UseColorRange = false;
I hope will helps.
