ShowEditor unhandled exception issue
Fang
Post by Fang » Thu May 12, 2005 9:03 pm
Hi all,
I am using VC++ 2003 .net and teechart .net beta
this is really weird. I am not sure if it's teechart problem or vc .net bug
Add a teechart, and some function in the form, whenever I reference pointer or recast, ex (*mat)(i,j) or (*char) in any of funtion. The tChart1->ShowEditor() will raise a unhandled exception at runtime, saying "DragDrop registration failed."
This must be a compile issue, 'cause the error is not raised by those function which contain the pointer code, but the ShowEditor(). And even I don't call those function, I still get that error. Funny, without ShowEditor(), the code works.
Anyway, I don't get error if I compile it in release mode.
Just curious if anybody had this before, or is it a known issue?
Best Regards
Fang
p.s By the way, teechart .net won't compile for 2005 vc++ .net express
Post by Christopher » Fri May 13, 2005 11:18 am
Hi Fang,
Mmm ... well, I've done some extensive tests adding functions into a designtime chart using the chart editor and have found a small problem which I have corrected. The problem was that some of the teechart code in the InitializeComponent() method wasn't correct having clicked on the "Apply" button in the datasource tab. I don't know if this is what was happening with you but would be very interested to find out; could you please give me some step by step instructions on how to reproduce the error at here?
No, we have created a teechart.dll (version 2, that is) which we compiled under the .NET Framework v2.0 but it is not publicly available at present.
Many thanks!
Thank you!
http://groups.google.com
http://codenewsfast.com/
Fang
Post by Fang » Fri May 13, 2005 3:11 pm
this must have something to do with the matrix(from boost.org) i am using. The following code had the above problem in debug mode. But I can't reproduce it if I replace the matrix_f to std::vector or other simple pointer. So maybe the template inside matrix messed up sth :)
typedef boost::numeric::ublas::matrix<float_t> matrix_f;
private: Steema::TeeChart::TChart * tChart1;
private: System::Windows::Forms::Button * button1;
private: Steema::TeeChart::Styles::ColorGrid * colorGrid1;
private:
matrix_f *m_Mat;
public:
Form1(void)
m_Mat=new matrix_f();
private:
System::Void FillSeries()
colorGrid1->Clear();
for (size_t i=0; i<m_Mat->size1(); i++)
for (size_t j=0; j<m_Mat->size2(); j++)
colorGrid1->Add(i,(*m_Mat)(i,j),j);
private:
System::Void button1_Click(System::Object * sender, System::EventArgs * e)
tChart1->ShowEditor();
