THorizBarSeries - scroll bar bug
marder
Post by marder » Fri Feb 06, 2009 2:09 pm
Hi.
I encounter a problem in TeeChart V8.04.
I have a Tchart with a TScrolbar on the right siede to scroll in my THorizBarSeries:
I there are many entries in my bar chart and I sroll the chart down, the chart is shown very strange:
I was not abel to reproduce this with V7.
I am using the Anti-Alias tool now, but deactivating did not fix this priblem.
Is this a know issue and are there any workarounds?
Thanks!
Post by Yeray » Fri Feb 06, 2009 3:31 pm
Hi marder,
I've tested it and it seems to work fine for me here. Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
marder
Post by marder » Mon Feb 09, 2009 12:15 pm
Hi Yeray.
I build a simple example project that shows the problem:
http://mail.jam-software.de/misc/BarCha ... roblem.zip
This project does not have the scrollbar included, but when using the mouse wheel for scrolling has the same effect.
I guess the problem is related to the property
Chart.MaxPointsPerPage
Thanks for your help!
Post by Yeray » Mon Feb 09, 2009 12:36 pm
Hi marder,
Yes, as you see your problem is the chart property MaxPointsPerPage. This property is used for the chart's paging feature but you are not using it. You are using a scrollbar so you need a variable or a constant to control the number of points to show. Here there is your code with a few modifications and it works fine for me here.
const  PointsShown = 10;
procedure TForm1.FormShow(Sender: TObject);
  Chart.SetFocus;
  DrawChart;
procedure TForm1.ScrollBar1Change(Sender: TObject);
  Chart.Axes.Left.SetMinMax(ScrollBar1.Position - 0.5, ScrollBar1.Position + PointsShown - 0.5);
procedure TForm1.DrawChart();
var
  I: Integer;
  BarSeries.XValues.Order := loNone;
  // Fill bar series with new values
  BarSeries.Clear;
  for I := 0 to 100 do
    BarSeries.Add(i, IntToStr(i));
  ScrollBar1.Max := BarSeries.Count-PointsShown;
  ScrollBar1.Min := 0;
  ScrollBar1.Position := 0;
  Chart.Axes.Left.SetMinMax(0 - 0.5, PointsShown - 0.5);
marder
Post by marder » Mon Feb 09, 2009 3:15 pm
Hi Yeray.
Thanks for this workaround.
This fixed the problem.
Anyway, since TeeChart V7 I try to use a TChartScrollBar to do my scrolling, but this seems not to work automatically by assigning the Chart property.
Is this a known issue or do I have to do any additional coding to get the TChartScrollBar to work?
Thanks and best regrads!
Post by Yeray » Tue Feb 10, 2009 8:58 am
Hi marder,
Yes, this is a known issue from TChartScrollBar that we'll investigate and that's why in the meanwhile we recommend using the standard ScrollBar.
marder
Post by marder » Tue Feb 10, 2009 2:03 pm
marder
Post by marder » Wed Feb 25, 2009 9:29 am
Hi.
I have an issue when using the down button of the standard scroll bar to.
With the down button I can scroll lower than the last bar of my chart:
I am using the following procedure as the OnScroll event of my scroll bar:
procedure TMainForm.ChartScrollBarScroll(Sender: TObject; ScrollCode: TScrollCode; var ScrollPos: Integer);
  Chart1.Axes.Left.SetMinMax(ScrollPos - 0.5, ScrollPos + fChartMaxPointsPerPage - 0.5);
  //fChartMaxPointsPerPage is a member holding the maximum shown bars in the chart
Can you please tell me if there is a workaround to avoid this behavior?
Will this behavior be fixed when using the TChartScrollbar (in case this component works correctly)?
Thanks!
Post by Yeray » Wed Feb 25, 2009 10:58 am
Hi marder,
Could you please verify that your TScrollBar has a is getting position values (ScrollPos) in your series' range? I mean, the scrollbar.min has the same value of your series Y min and the scrollbar.max has your series' max Y value (-PointsShown).
If everything seems ok, could you try to make a simple but complete example we can reproduce here?
marder
Post by marder » Wed Feb 25, 2009 1:58 pm
Hi.
I just realized that this is a problem of the TScrollBar (When customizing the property PageSize).
Anyway, I would really appreciate if the TChartScrollbar will finally work correctly in one of the next releases of TeeChart!
