Teechartpro 7.12 Drawing a graph
Clara Genermont
Post by Clara Genermont » Fri Aug 01, 2008 9:24 am
Hi Narcis,
Can we draw the graph of any function with
teechart directly with his equation?
Thank you for your help
Didier
Post by Narcís » Fri Aug 01, 2008 9:35 am
Hi Didier,
Yes, you can use custom function. You'll find an example at All Features\Welcome!\Functions\Extended\Custom y=f(x) in the new features demo, available at TeeChart's program group.
Clara Genermont
Post by Clara Genermont » Sun Aug 03, 2008 9:37 pm
thank you Narcis,
but I can't draw a function like this
y=2+3*(1+x)-5 + (abs(-x^2) - x*x) * 2 - 1/(x + 1)
or yet
y=sinx + cosx - abs(tanx) + x
How can draw them ?
I don't understand how to intoduce this equation...
Can you show me an example ?
thank you very much for your help
Didier
Post by Yeray » Mon Aug 04, 2008 7:41 am
Hi Clara,
This works for me here.
procedure TForm1.TeeFunction1Calculate(Sender: TCustomTeeFunction;
  const x: Double; var y: Double);
  //y := 2+3*(1+x)-5 + (abs(power(-x,2)) - x*x) * 2 - 1/(x + 1);
 y := sin(x) + cos(x) - abs(tan(x)) + x;
Clara Genermont
Post by Clara Genermont » Mon Aug 04, 2008 5:06 pm
sorry but
what is TeeFunction1Calculate ?
event, object or a component ?
thank you in advance
Post by Yeray » Tue Aug 05, 2008 8:21 am
Hi Didier,
It's an event for TCustomTeeFunction. You should find it through Object inspector as usually if you added the function at design time (at the function object, not the series).
Clara Genermont
Post by Clara Genermont » Tue Aug 05, 2008 3:13 pm
Yès, il found it and I choose Y= f(x)
but Idon't see the event ! (F11 on the Teechart)
thanks
Didier
Post by Marc » Tue Aug 05, 2008 4:02 pm
Hello Didier,
When the function has been selected by editor, close the editor and F11 will take you to the object inspector. Select 'TeeFunction1' from the drop-down combobox and click on the Object Inspector's Events tab. From here you can select the event.
Clara Genermont
Post by Clara Genermont » Wed Aug 06, 2008 9:35 am
I don't see the event
I choose "functions" and "y = f(x)"
then in the combobox I see Y= f(x) not TeeFunction1
and on F11
I don't see "OnCalculate"
nb:
version 7.12[/url]
Post by Yeray » Thu Aug 07, 2008 7:29 am
Hi Didier,
That's strange. You should see a series and a teefunction.
Another test you can do could be to add a chart (and a function) to a new form at design time and see the declarations in the code generated. For me:
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TLineSeries;
    TeeFunction1: TCustomTeeFunction;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
Clara Genermont
Post by Clara Genermont » Thu Aug 07, 2008 12:31 pm
yès !
that's good !!! :D :D :D :D :D
I had a little concern with the installation...
THANK YOU VERY MUCH
Post by Yeray » Fri Aug 08, 2008 7:27 am
Hi Didier,
I'm happy to see that!
Post by Narcís » Mon Nov 24, 2008 11:02 am
Hi Didier,
Please notice that I have splitted your last post into a new topic:
http://www.teechart.net/support/viewtopic.php?t=8798
It's better starting a new topic for each now issue. It's easier to follow up.
nitin
Post by nitin » Mon Apr 27, 2009 9:19 am
Hi Narcis,
How can I Draw this function with TeeFunction1Calculate
with three parameters :
Qf, S, Sa that can be defined by double
(exemple : Qf = 1, S = 8, Sa =4,3)
y := (Qf * S * 0.36 * x) / Sa;
for this moment, I have a message "operation en virgule flottante incorrecte"
Didier
Post by Narcís » Mon Apr 27, 2009 9:42 am
Hi Didier,
You can do this:
const
  Qf = 1;
  S = 8;
  Sa = 4.3;
If those constants need to be modified then you can create them as global variables in your unit.
Hope this helps!
