Teechartpro 7.12 Drawing a graph
Post by Narcís » Mon Apr 27, 2009 10:15 am
Hi Didier,
For completeness, you may get this error because those variables are not initialised when the OnCalculate event is called. To solve this problem you can do something like this:
procedure TForm1.TeeFunction1Calculate(Sender: TCustomTeeFunction;
  const x: Double; var y: Double);
  if ((Qf<>0) and (S<>0) and (Sa<>0)) then
    y := (Qf * S * 0.36 * x) / Sa;
  Qf := 1;
  S := 8;
  Sa := 4.3;
  Series2.CheckDataSource;
nitin
Post by nitin » Mon Apr 27, 2009 3:25 pm
Hi Narcis,
I do this but doesn't works...
look at the code :
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, TeEngine, TeeFunci, Series, ExtCtrls, TeeProcs, Chart, Math,
  StdCtrls;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TLineSeries;
    TeeFunction1: TCustomTeeFunction;
    Series2: TLineSeries;
    TeeFunction2: TCustomTeeFunction;
    procedure TeeFunction1Calculate(Sender: TCustomTeeFunction;
    procedure TeeFunction2Calculate(Sender: TCustomTeeFunction;
  private
    { Déclarations privées }
  public
    { Déclarations publiques }
var
  Form1: TForm1;
  a, b, Qf, S, Sa: Double;
implementation
{$R *.dfm}
  y := a * power(60 * x, 1 - b); //  First function works fine
procedure TForm1.TeeFunction2Calculate(Sender: TCustomTeeFunction;
  y := (Qf * S * 0.36 * x) / Sa; // second function ?????
  a := 28.916;
  b := 0.848;
  Qf := 1;
  S := 8;
  Sa := 4.3;
  Series1.CheckDataSource;
end.
Thank you for your help
Didier
Post by Narcís » Mon Apr 27, 2009 3:29 pm
Hi Didier,
At TeeFunction2Calculate you should check that those variables are not zero, as in the example I posted and then you may also need to run CheckDataSource on Series2 too.
nitin
Post by nitin » Tue Apr 28, 2009 3:30 pm
Thank you very much Narcis
all works fines !
Another question :
How now to show two values on each of the curves
and draw a straight line between these points ? (same x, two y different)
thank you in advance
Didier
Post by Yeray » Wed Apr 29, 2009 9:58 am
Hi Didier,
If I understand fine, the easiest way to do this probably would be adding a new line series with two points (one from the first function and one from the second). Here is a complete example:
var a, b, Qf, S, Sa: Double;
  Chart1.View3D := false;
  a := 28.916;
  b := 0.848;
  Qf := 1;
  S := 8;
  Sa := 4.3;
  Series3.AddXY(Series1.XValue[5],Series1.YValue[5]);
  Series3.AddXY(Series2.XValue[25],Series2.YValue[25]);
  Series3.Pointer.Visible := true;
Clara Genermont
Post by Clara Genermont » Wed Apr 29, 2009 1:58 pm
Hi Narcis,
Thank you very much
We are soon at the end of the problem ..
But a small concern of conversion that I do not understand because
AddXY expected and provide double
but the message indicates an incompatibility between integer and double ..
Look at the code :
unit Unit1;
interface
uses
  StdCtrls;
type
    Chart1: TChart;
    Series3: TLineSeries;
    TeeFunction3: TCustomTeeFunction;
  private
  public
var
  Form1: TForm1;
  a, b, Qf, S, Sa, calcul, tc,y1,y2: Double;
implementation
{$R *.dfm}
  if ((Qf <> 0) and (S <> 0) and (Sa <> 0)) then
  a := 28.916;
  b := 0.848;
  Qf := 1;
  S := 8;
  Sa := 4.3;
 // calculate the critical value :
  tc := exp(-ln((Qf * S * 0.36) / (Sa * (1 - b) * a * power(60, 1 - b))) / b);
// determination of the Y values of the two curves to the value tc
  y1 := a * power(60 * tc, 1 - b);
  y2 := (Qf * S * 0.36 * tc) / Sa;
//  Draw a line between the two points
  Series3.AddXY(Series1.XValue[tc], Series1.YValue[y1]);   // error on this line !!!
  Series3.AddXY(Series2.XValue[tc], Series2.YValue[y2]);
end.
Thank you in advance for your help
Didier
Clara Genermont
Post by Clara Genermont » Wed Apr 29, 2009 2:05 pm
Of course, I tried this :
  Series3.AddXY(Series1.XValue[Trunc(tc)], Series1.YValue[Trunc(y1)]);
  Series3.AddXY(Series2.XValue[Trunc(tc)], Series2.YValue[Trunc(y2)]);
But, is not good..
Didier
Clara Genermont
Post by Clara Genermont » Wed Apr 29, 2009 2:30 pm
I think I have found :
 Series3.AddXY(tc,y1);
 Series3.AddXY(tc,y2);
have you better ?
Didier
Post by Yeray » Wed Apr 29, 2009 2:40 pm
Hi Didier,
1. I think that you have added a 3rd function but I think that you only need a line series.
2. You should give the X and Y points to the method Series3.AddXY. You could calculate as you are doing with tc and y1 and y2. Then, I think that this should result in the following:
unit Unit1;
interface
uses
  Dialogs, TeEngine, TeeFunci, Series, ExtCtrls, TeeProcs, Chart, Math;
type
    Chart1: TChart;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
implementation
{$R *.dfm}
  a := 28.916;
  b := 0.848;
  Qf := 1;
  S := 8;
  Sa := 4.3;
  Series3.AddXY(tc, y1);
  Series3.AddXY(tc, y2);
end.
Clara Genermont
Post by Clara Genermont » Mon May 04, 2009 11:47 am
Hi Yeray
thank you,
Answers were cross ..
Didier
Post by Yeray » Tue May 05, 2009 10:02 am
Hi Didier,
Yes, I should refresh the page before sending the message :P
I'm happy to see that works fine for you.
