QuickReport5 and Delphi - Works
Lucien
Post by Lucien » Thu Jul 17, 2008 6:24 am
I am using Delphi 2006 and had a problem with installing Quick reports 5 and you sent me an upgrade because of qRTEE.PAS. Now iT WORKS perfect ie. version 8.03.
However when I use the TColorGrid series the color grid is one row and column too short. i.e. when the Marks.Visible property is True this is very apparent.
I found that the Surface series also has the same problem ie. one column and row are missing from the drawn series. This problem occures in the Tchart component.
Old code that worked correctly with older versions of TChart Ver 8.02 now does not work. Please help?
Solution - I saw that some had problems with the instalation of QuickReport5 because of QRTee having being compiled with different version.I got around this by simlpy coping the QRTee.pas file to one of the folders of TeeChart that the Delphi compiler had access to.The Result was that the QRTee file was recompiled.
I found Quick Report's new version - 5 to be a valuable asset to my software tools and the compatability between TChart and Quick Report 5 are thus important.
Lucien
Lucien
Posted: Mon Jun 23, 2008 11:30 am Post subject:
Lucien
Post by Narcís » Thu Jul 17, 2008 7:40 am
Hi Lucien,
Thanks for the information. Yes, ColorGrid/Surface series issue is a known one (TV52012634) which we will try to fix ASAP.
