DELPHI 2006 TCHART 8.03
Posted: Fri Jun 20, 2008 3:37 pm
by 10047009
I had a problem with installing Quick reports 5 and you sent me an upgrade because of qRTEE.PAS. Now iT WORKS perfect.
However when I use the TColorGrid series the color grid is one row and column too short. i.e. when the Marks.Visible property is True this is very apparent.
Old code that worked correctly with older versions of TChart Ver 8.02 now does not work. Please help?
My temp email is : heuserchen@web.de as I am on holiday.
Posted: Mon Jun 23, 2008 11:30 am
by 10047009
I found that the Surface series also has the same problem ie. one column and row are missing from the drawn series. This problem occures in the Tchart component.
Lucien
