Can I modify and recompile TeeChart source code?
Ryderbay
Post by Ryderbay » Fri Apr 16, 2004 8:54 am
I have another question...
Can I modify and recompile the TeeChart source code?
I bought TeeChart Pro 7 with source code.
I thought that's full source so, I tried to modify and recompile that.
When I did not modify, recompile was OK.
But modified, Error detected.
How can I modify and recompile the TeeChart source?
Post by Pep » Fri Apr 16, 2004 9:51 am
Yes, of course. If you've source code version you can change something in source code and rebuild it.
So, this indicates that something that has you done is wrong.
Normally, as other project. Once you've modified you should recompile it floowing the instructions you can see in the install.txt file (included in the TeeChart Pro v7 Source Code installation).
