Quick Report IV Components for TeeChart8 & TeeTree
Lucien
Post by Lucien » Wed Oct 17, 2007 10:27 am
I am using Delphi 2006, I have managed to load the Quick Report IV component for TeeChart. I found there was an error with the naming of two requirement files. One for each of the compilations. Once I renamed them it worked correctly.
I need the files for TeeTree so that Quick Reports will print this component. I have previously used this with TeeTree7.
Can you assist?
Post by Narcís » Wed Oct 17, 2007 10:33 am
Hi Lucien,
We don't have such packages ready. In that case you could upgrade their TeeChart v7 references to v8, compile and install them.
Post by Narcís » Tue Oct 23, 2007 8:39 am
Hi Lucien,
As an update, we are currently working on arranging the packages you requested. We will let you know when they are ready.
Lucien
Post by Lucien » Wed Oct 24, 2007 9:40 am
Hi Narcís,
I managed to compile, build, instal the components for TeeChart to work with Quick Reports V 4.07. Delphi 2006. Works fine at design time but at runtime when trying to preview I get Metafile Error. I think it says "invalid Metafile". Any Ides ?
Regards Lucien
PS: I see you guys have been taking flack with issues with Quick reports from some customers. Please be encouraged I think the advances in the product far outway the snags. Keep up the good work.
Lucien
Post by Lucien » Thu Oct 25, 2007 4:39 am
Hi Narcís,
I followed detailed instructions on installing Teechart comp. for Quick Reports it works fine.
Lucien
