[Solved] [v8] Bug with TAxisScrollTool
bertrod
Post by bertrod » Thu Aug 30, 2007 10:54 am
I found a problem with the TAxisScrollTool which I think occurs only with Version 8.
When I'm scrolling an Axis using this tool, everything works fine except when the cursor is exactly over the axis line ! This behaviour looks strange and I think it is a bug.
To reproduce it, simply scroll the axis up and down, and move the mouse cursor over the axis line while scrolling.
This behaviour occurs also with TeeChartOffice 3.0.
Post by Narcís » Thu Aug 30, 2007 1:39 pm
Hi bertrod,
I'm not able to reproduce the problem here. I've made a little example and I've sent you its .exe. Could you please try running it at your end and let me know if it works fine for you?
bertrod
Post by bertrod » Thu Oct 18, 2007 8:26 am
Hi Narcis,
The exe you sent me worked fine. After some time, I finally could solve my problem with the AxisScrollTool.
I don't know if it can help you in any way, but here is my modification to solve this problem:
File : TeeTools.pas
Function : TAxisScrollTool.ChartMouseEvent
SubFunction : AxisClicked
OLD CODE
    if Assigned(Axis) then
      if Axis.Visible and Axis.Clicked(x,y) then // <-- prob here: Axis.Clicked returns False
         result:=Axis;
    end
    with ParentChart do
    for t:=0 to Axes.Count-1 do
        if Axes[t].Visible and Axes[t].Clicked(x,y) then
          result:=Axes[t];
          break;
NEW CODE
         result:=Axis
      { MODIFICATION START }
        with ParentChart do
              result:=Axes[t];
              break;
      { MODIFICATION END }
    end
    with ParentChart do
          result:=Axes[t];
          break;
Mybe it will help you understand what was going wrong with my tool. The variable "Axis" was correct, but Axis.Clicked always returned False when the mouse was exactly over the Axis line. Really strange problem I guess.
Post by Narcís » Mon Oct 22, 2007 1:37 pm
Hi bertrod,
Thanks for the information. I'm glad to hear you could solve the problem. This works fine here using our current sources.
