Installation Problems
ha28301
Post by ha28301 » Wed Mar 14, 2007 8:20 am
I just tried to install TeeChart7.08Delphi2006.exe, but it doesn´t install correctly:
* no paths are added to Delphi´s Library Search
* pressing F1 in Delphi leads to no help (theme does not exist)
:twisted: [/list]
Post by Narcís » Wed Mar 14, 2007 8:25 am
Hi ha28301,
Can you add a TChart into a form and run the application or do you receive any error message? If so, which error message/s do you get?
This is a known issue as told here.
ha28301
Post by ha28301 » Wed Mar 14, 2007 8:36 am
narcis wrote:Hi ha28301,
:? "Can you add a TChart into a form and run the application ": yes, no error message
Post by Narcís » Wed Mar 14, 2007 8:50 am
Hi ha28301,
Thanks for your reply.
Then I don't see any problems in no paths being at the Search Path list. TeeChart v7.08 installer already removed TeeChart v4.04 Standard and installed new packages successfully. Is this causing you any problem?
ha28301
Post by ha28301 » Wed Mar 14, 2007 9:17 am
:) I just noticed, that you describe in "INSTALL.TXT", §2, that \Lib-location is added to Delphi, and that it is NOT added. I do not know if this will cause problems in the future.
