Area Graph Question
mh
Area Graph Question
Post by mh » Wed Mar 07, 2007 9:42 pm
When I'm graphing a single point, the area graph only shows a single dashed verticle line up the the value of the point.
Is there any way to change the display of the graph so it draws the single point from the bottom-left of the chart window to the point to the bottom-right of the chart window? This would then show a single point essentially as a pyramid. As it is, viewing a single data point sometimes confuses the customer because it looks like nothing was graphed.
Post by Yeray » Thu Mar 08, 2007 9:53 am
Hello mh,
To plot an area series you should have, at least, two points to define a valid area to be plotted. Anyway, if you wish to achieve what you request you could use something like the AddValue method and OnGetPointerStyle event (to show the points you need) as in the example we implemented below.
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, TeEngine, Series, ExtCtrls, TeeProcs, Chart, StdCtrls, TeeComma;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TAreaSeries;
    Button1: TButton;
    TeeCommander1: TTeeCommander;
    function Series1GetPointerStyle(Sender: TChartSeries;
      ValueIndex: Integer): TSeriesPointerStyle;
    procedure Button1Click(Sender: TObject);
  private
    { Private declarations }
    OnePoint: boolean;
    procedure AddValue(y: double);
  public
    { Public declarations }
var
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.AddValue(y: double);
     if Series1.Count = 0 then
          OnePoint:=true;
          Series1.Add(y-1);
          Series1.Add(y);
          Series1.Add(y-1);
     end
           if OnePoint then
                Series1.Delete(0);
                Series1.Delete(Series1.Count-1);
                Series1.XValues.FillSequence;
                OnePoint:=false;
           Series1.Add(y);
  Series1.Clear;
  Series1.Pointer.Visible:=true;
  OnePoint:=false;
  AddValue(random);
function TForm1.Series1GetPointerStyle(Sender: TChartSeries;
  if OnePoint then
    if (ValueIndex = 1) then
       result := psRectangle
        result := psNothing;
  end
    result := psRectangle;
     AddValue(random);
end.
mh
Post by mh » Thu Mar 08, 2007 3:57 pm
Thanks for the tip. However we are utilizing the graph inside of a Report Builder report, so we don't have programmatic access to it. I guess we'll have to adjust the data or select another report style.
Thanks again
Post by Narcís » Thu Mar 08, 2007 4:06 pm
Hi mh,
If you don't have access to all those events and properties in Report Builder you could use an invisible TChart, export it to an image and then load the image into Report Builder. For more information on how to export TeeChart to images please read Tutorial 12 - Exporting and Importing Charts. You'll find the tutorials at TeeChart's program group.
